Hi all,
Is there a way to scale up a default block and its linetype scale together without manually adjusting each drawing in the Block Editor?
I've been testing LTSCALE and MSLTSCALE and found settings that work with the Annotation scale, but this only applies to Model space. The linetype scaling doesn't work in Paper space.
Any solutions for consistent linetype scaling in both Model and Paper space?
Thanks.
Solved by h_s_walker. Go to Solution.
PSLTSCALE is the variable you need to change. See the link below
AutoCAD 2022 Help | PSLTSCALE (System Variable) | Autodesk
Howard Walker
