- Mute
- Permalink
- Report
I thought that using the PDFIMPORT command that I could import a hand drawn scaled drawing by creating a scanned PDF drawing and then importing that PDF to create a new .dwg file. I now know that Autocad does not recognize the objects in the drawing unless the original PDF was created in Autocad vs a scanned version.
I know that I can Xref the PDF hand drawn file into model space and draw over top of the PDF to create a new Autocad .dwg layout with the appropriate layers but its is not very accurate
Is there another way to import the hand drawn scaled layout drawing and convert it to a .dwg in Autocad ?
Paul
