- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
How would you add spacing just around the +/- sign when adding tolerances to dimensions in autocad? I know about the prefix and suffix options in the dimension style properties manager, but when I add spaces to them, autocad removes my dimensions from the primary units.
For example:
I want to format the following using the dimensions style manager:
[6mm +/- 1mm] (Note the spaces around the +/- symboll.)
I've currently got my suffix option set to 'mm', but this only creates the following:
[6mm+/-1mm]
When I change the prefix property to ' ' and the suffix property to ' mm', I get this:
[6+/-1mm] (Autocad removes the 'mm' units from the primary dimension. I don't know why.)
That being said, even if Autocad didn't reformat the units as above, I believe I would still get the following:
[ 6mm +/- 1mm ]
This I would find acceptable, but I'd prefer it without the spaces next to the brackets.
