How To Fit 4 Tangent Circles between 2 Radii and Tangent To Lines That Pass Through The Center Of A Circle
anthony53CX7
Message 1 of 11
anthony53CX7
Hello All,
First time posting on this forum. I would like to know if there is a way to fit 4 circles between these radii. The purple radii can not move. The red circles/lines can change. There need to be 4 circles. the red lines need to go through the center of the purple circles. These red lines need to be tangent to the red circles as well. The 4 red circles also need to take up the entire space (Right now I'm off by about 0.005). Please let me know if you need any additional information. Thank you.
Replies (10)
Message 2 of 11
pendean
Community Legend
Community Legend
Share your DWG file here please.
Message 3 of 11
anthony53CX7
Attached the DWG Here
Message 4 of 11
Brock_Olly
I don't think there's a way to automatically do this in autocad but I'm sure it can be done with trigonometry though I'm not smart enough for that it seems
Message 5 of 11
Brock_Olly
I asked chatGPT and he struggled quite a bit, had to change prompt around a lot but he might be on to something:
Message 6 of 11
Washingtonn
What was your method up to this point?
Can you show your work?
What is an acceptable tolerance?
Message 7 of 11
anthony53CX7
Up to now I kept adjusting the radius of the top circle, creating tangent lines from the center of the radii to the top circle, and then used TTT to create the other 3 circles. I was able to get it within ~1/128in. I was hoping to find a way to make it perfect without using geometry/equations.
Message 8 of 11
Washingtonn
The black circles are to remain after erasing all other lines....
Message 9 of 11
anthony53CX7
Thank you for your response. This does get it to be close, but this is not exactly what I was looking for. Thank you for the alternative way of getting the circles close though.
Message 10 of 11
Washingtonn
Even using Solver in Excel (though you didn't want to use formulas.....), a small tolerance remains (0.00000097) in the distance between diameters and differences between arcs.  What is the purpose/use?
Message 11 of 11
anthony53CX7
I had a project that needed this to be done within a tolerance. I was genuinely curious if it was possible to get the tolerance down to 0. Thank you for the help though!
