How to delete multiple layouts on Paper Space?
syanchuck
Message 1 of 24
syanchuck
Is there a command to remove multiple layout of the Paper Space, not just selecting one by one?
Thank you in advance!!
Replies (23)
Message 21 of 24
syanchuck
Tried and tried again and that worked finally!
Message 22 of 24
syanchuck
I need you help again.
It worked, after I asked to solution, but for some reason it stopped working.
I am selecting all layouts, but ones I want to deselect one of layouts, the function is selecting it instead of deselecting and deleting the layout I wanted to deselect.
Do you know some tip how make it work?
Message 23 of 24
RSomppi
Use the Ctrl key to deselect.
Message 24 of 24
Brock_Olly
Not sure if 2019 has this menu, but you can go to your first layout, then open the hamburger menu on the left, and while holding shift click on the last layout, then right click > delete.
