How to Create a .PAT file for custom hatches?
Message 1 of 9
Hi, I am trying to create a custom hatch. I made the hatch in a autocad drawing, made it into a block, and saved it as 6x18subwaytile.PAT
It is not showing up as a .PAT file in my files. I also am not sure how to add this into AutoCAD to use.
Replies (8)
Message 2 of 9
Edwin.Rense
As you can see (from your attachment), your file extention is still dwg.
It should be a regular .pat
A .Pat file contains The placement of the lines (start, end and direction)
Also the pattern start coordinates.
take a look at the Acadlt.pat in the %appdata%\Autodesk\AutoCAD LT 2022\R28\enu\Support folder.
Open it in notepad.
All you see is 'text'
Look for the lines which represent the AR-B816 hatch, this is an 8"x 16" tile.
*AR-B816, 8x16 Block elevation stretcher bond
0, 0,0, 0,8 -> Is horizontal line
90, 0,0, 8,8, 8,-8 -> vertical lines
Copy these 3 lines beneath the "User defined Hatch pattern section.
Your subway tile is 6"x18",
Change to:
*SUBWAY616, 6x16 Subway Tile
0, 0,0, 0,6
90, 0,0, 6,6, 6,-6
Save the pat file.
Open AutoCAD and apply the hatch.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
Message 3 of 9
steven-g
Take a look at this site.
A hatch pattern .pat file does not use a block it is a text description telling Autocad how you want the pattern to be drawn. In your case the .pat file should read
*6x18, Tile
0,0,0,0,6
90,0,0,6,9,6,-6
Message 4 of 9
steven-g
Change to:
0, 0,0, 0,6
90, 0,0, 6,6, 6,-6
Save the pat file.
Slightly confusing
you talk about a 6x18 pattern
label it as 6x16
and it creates 6x12 😀
Message 5 of 9
Edwin.Rense
You are completely correct, changing back and forth from imperial to metric still is confusing. 😎
Yours will work better:
*6x18, Tile
0,0,0,0,6
90,0,0,6,9,6,-6
Kind regards,
Edwin Rense
Cadac Group AEC BV
Cadac Group .
Message 6 of 9
pullstackautocad
Namaste from nepal can you please help me with the section....
Message 7 of 9
pullstackautocad
Message 8 of 9
doni49
Rather than bringing up an old thread to request advice, it's usually a better idea to start a NEW thread in which you reference (by way of a link) the old thread. For better or worse, a lot of people tend to pass right on by old threads. Others specifically use the "UNANSWERED" tab above as a means to find threads in which they might assist someone -- that specifically filters for threads with ZERO replies. If your post is a reply to someone else's thread, then that thread will be filtered out.
When you post a new thread, you have a better chance of getting more eyes on the question. That equates to a broader range of knowledge which in turn leads to improved chances of resolving your issue.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 9 of 9
Edwin.Rense
@pullstackautocad
I had an entire message ready but it didn't upload.
So a shorter one now.
Due to the equal X and Y coordinates bottom and left, and the same for top and right, this hatch is not possible.
The blue squares need an offset from bottom and left to create a single hatch.
If the color need to be different you must use two seperate hatches.
With the offset the pattern would be this:
The pattern file lines would be:
*1100x1100, Tile
0, 55,55, 1210,1210, 1100,-110
90, 55,55, 1210,1210, 1100,-110
0, 55,1155, 1210,1210, 1100,-110
90, 1155,55, 0,1210, 1100,-110
0, 0,1210, 1210,1210
90, 1210,0, 1210,1210
Hope this works for you.
Kind regards,
Edwin Rense
Cadac Group AEC BV
Cadac Group .
