How to clear PDF Page labels when exporting to PDF
tran.nhat.anh
Observer Observer
Message 1 of 8
tran.nhat.anh
Observer
Observer
I would like to ask how to clear PDF page labels as below.
Version : Autocad LT 2020
Problem : when exporting to PDF by export pdf or publish ( single sheet or multiple sheets) , pdf page labels has included file name + layout out.
I just want to keep it as page number as before ( LT 2015) . I can change page labels in pdf after exporting, but i want to know there is setting inside autocad or not ?
Thank you
Replies (7)
Message 2 of 8
maratovich
You need to watch the Publish settings.
But this does not help with the page number, it will always be in brackets.
To change the name in pdf use this: LabelsPDF
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 3 of 8
tran.nhat.anh
Observer
Observer
Dear Mr/Ms Maratovich (Collaborator)
Thank you for your reply.
As I said, I can change page labels later in Adobe using page labels and re-page number to number style.
And I already checked in Publish setting, there is no option about this pdf labels neither.
Thank you your attention
Message 4 of 8
pendean
Community Legend
Community Legend
Post a screenshot of your PUBLISH command pop-up (and a screenshot of the PDF showing the list of pages that came from that PUBLISH action) for an explanation of what was recommended above: also, do you use SSM (SheetSet Manager)?
Message 5 of 8
tran.nhat.anh
Observer
Observer
Please find my Publish screen ( Autocad LT 2020) as below . I am sorry its in japanese, but its I think you can compare with English version.
After making pdf, PDF labels as like red marks which i dont want to be like below. ( pdf labels = file name + layout name )
After clearing PDF labels, only page number left. This is my required result. So I just wonder that in Autocad, there is some settings to prevent making PDF labels like above. I have no problem when using Autocad LT 2015.
Message 6 of 8
pendean
Community Legend
Community Legend
You need to manually change the name of your "sheet" here in the PUBLISH command dialog box to get the results you desire:
If you use SSM (SheetSet Manager) with your project files, and rename each layout there, then PUBLISH will automatically populate the new names for you.
I no longer have LT2015 so I have no idea how different it was from now.
Message 7 of 8
tran.nhat.anh
Observer
Observer
But I prefer edit in Adobe reader after exporting, its more faster than manually modifying in Publish
Thank you for your attention.
Message 8 of 8
pendean
Community Legend
Community Legend
Then you will continue to have the same problems.
Best wishes.
