I am wanting to know how I can either change the 'Z' axis into the 'X' or 'Y' axis or move items from the 'Z' axis to the 'X' or 'Y' axis on AutoCAD LT.
I use a laser templater and the software that comes with it is full 3D. I can export this to a DXF so I can work on it in AutoCAD LT. Typically I'm measuring flat countertops and the like, so when I export to a DXF, the drawing is essentially in the 'X' and 'Y' axis, and I flatten any height in the 'Z' axis to '0'.
However, I've measured a vertical element, so the drawing is mainly in the 'Z' axis. When I copy the drawing/elements into AutoCAD LT, what is a rectangle in the 'Z' axis essentially appears as a line, because in essence you are viewing the rectangle from above.
I would like this 'rectangle' to be in the normal 'X' and 'Y' axis. Is there a way of doing this?
Thanks.
