How to array Isocircle ellipse on Isocircle ellipse
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Looking for help on how to array an ellipse around an ellipse in isometric view.
I've attached a drawing. As you can see I've created isometric views of a 'flat' panel with a 'fluted' detail. However I want to draw an isometric view of a curved panel of the same design. These are cladding panels that go around a corner/radius.
I realise this is possible in full AutoCAD as it has 3D capabilities, but looking for help on how to achieve this in AutoCAD LT with the isometric function.
If I draw an ellipse to show an isometric view of the top of an individual 'flute', and then array around the bigger ellipse, which is the top of the curved panel itself, I can't seem to space the 'flutes' so they are meeting at a tangent with each other all the way round. Obviously all the 'flute' ellipses need to be in the same orientation, as opposed to aligned with the bigger ellipse and this means the spacing between them changes as they go round.
I also started trying another way where I used a spline and converted to a polyline so I could manually drop on ellipse centres at each of the vertices, but I don't know how you would accurately work out the 'precision' of the polyline so that each of the vertices is one 'flute' apart.
In the drawing, the largest ellipse is the external diameter of my curved panel and the yellow line is the centre point of each flute. The ellipse inside that is the internal diameter of my curved panel. I have put one 'flute' at the bottom in the middle, but the start point of the yellow ellipse is on the right hand side. the other ellipses are actually 'isocircles'.
