How do I turn off the "selection" box popup?
yoreland1
Observer Observer
Message 1 of 10
yoreland1
Observer
Observer
Just a few days ago Autocad LT started popping up a selection box every time I try to execute a drafting command like trim, draworder, fillet, etc. I've been using autocad for 23 years and I've never seen nor needed this annoying pop-up. How can I turn it off? I tried "options" but can't figure it out. It's driving me nuts!
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
@yoreland1 wrote:
... for 23 years and I've never seen nor needed this annoying pop-up..
You turned this classic old tool on, and can turn it off the same way or by looking up this old command in the program's HELP
HTH
Message 3 of 10
yoreland1
Observer
Observer
Thank you! It turned itself on. I don't have that button visible on my lower task bar... so I used the command "selectioncycling" and switched it to 0. Fixed.
Message 4 of 10
ryanJXT2L
how do you turn it off permanently, as it keeps toggling on every time I restart?
Message 5 of 10
pendean
Community Legend
Community Legend
Message 6 of 10
ryanJXT2L
thanks, but as I clearly stated, I already did that, and as noted, it keeps restarting every time I open autocad.  I'm looking for a solution that permanently toggles it, without having to re-toggle every time I open autocad or open a new drawing.
Message 7 of 10
pendean
Community Legend
Community Legend
@ryanJXT2L wrote:
...it keeps restarting every time I open autocad....
Then you have a startup or routine or custom actions or shortcuts that are turning it back on for you since I have SELECTIONCYCLING turned off permanently as I guided and it's never come back on "by itself".
Inside your AutoCAD, post a screenshot of your ABOUT command pop-up plus the DDSETTINGS command pop-up at the SELECTION CYCLING tab please.
@ryanJXT2L wrote:
..thanks, but as I clearly stated, I already did that...
Nope, you did not, unless the two different logins (from 2026 and 2024) are you, in which case how would anyone around here know that?
Message 8 of 10
rafael4AHFJ
i TURN THIS OFF EVERY MONTH OR SO. it keeps turning on randomly. I want to delete this from the source code. I keep coming to this post.
No, i dont accidentally turn it on. I don;t have the icon visible, I've used autocad since it was called AUTOCAD R14, no, not 2014... R14. Way older.... and only since acad 2025 this is happening. I know what I'm doing in autocad (most of the time) and I use mostly keyboard commands. trust me BRO this selection window keeps coming up on its own. It's alive
Message 9 of 10
pendean
Community Legend
Community Legend
@rafael4AHFJ Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
HTH
Message 10 of 10
reece_guru
Community Visitor
Community Visitor
Thanks it worked.
In my case it showed as "disabled" even though it was active. I had to enable then disable it. Then the silly popup disappeared.
