How do I toggle between viewports
Message 1 of 26
How do I toggle between viewports in Autocad LT 2017 and 2018
Replies (25)
Message 2 of 26
cadffm
Message 3 of 26
Doesn't work.
Message 4 of 26
cadffm
Ok i will take a look tomorrow. (11:59 pm local time)
Had you redefine some Shortcuts?
It should work. No reaction or messages appears?
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Au...
Sebastian
Message 5 of 26
pendean
Community Legend
Community Legend
What doesn't work exactly? CTRL+R has always and still does take you from inside one paperspace viewport to another in the same layout, including LT2017 and LT2018.
If you are positive this does not work in ALL layouts with multiple viewports in ALL files you have, let us know. If the problem is unique to one DWG file, post it here and tell us which layout you are having trouble with.
Message 6 of 26
It does it with ALL drawings. The toggle doesn't work.
Message 7 of 26
steven-g
You do have to have one viewport active to start with, it won't work otherwise.
Message 8 of 26
pendean
Community Legend
Community Legend
Go to your layout.
Enter your layout, be inside it.
Try CTRL+R again. if it fails, post a full screenshot of your program window while you stay/are in your viewport, I want to see your entire full screen as you see it.
This is how to do screenshots in WIndows for free https://support.microsoft.com/en-us/help/13776/windows-use-snipping-tool-to-capture-screenshots
Message 9 of 26
The one viewport is opened. I have at least 3 or more viewports. Plus I have the VP freeze for each viewport.
Example: I have Demolition and Renovated on one layout with each one unique from the others.
Message 10 of 26
pendean
Community Legend
Community Legend
Message 11 of 26
I'm using the Maximize Viewport. I know the older version of AutoCAD LT had the ability to switch between the viewport.
Message 12 of 26
h_s_walker
Ctrl+R does not work with a "Maximised viewport" You need to be in the normal paperspace view to use Ctrl+R
Howard Walker
Left Handed and Proud
Message 13 of 26
Where did the ability go? I used the switch between VPMAX almost all the time.
Message 14 of 26
pendean
Community Legend
Community Legend
>>>...I know the older version of AutoCAD LT had the ability to switch between the viewport....<<<
Not in that mode: you remember incorrectly about older versions.
Message 15 of 26
AutoCAD LT 2017 for MAC has the ability to switch between viewports when you are in the VPMAX mode.
There is an image from the MAC version.
This ability was on the windows version at one time and I wish it was back on AutoCAD LT
Message 16 of 26
steven-g
Thats vpmax, something completely different
If your not seeing it you need to turn the icon on from the customisation menu.
Message 17 of 26
It's showing.
The only thing is different is that there is no arrows to go to the next or previous vports in the Windows version of AutoCAD LT. (I don't know if the full version of AutoCAD as it.)
I have multiple vports and I need to easily go between them without having to use the VPMIN then click on the other vports, then use the VPMAX  to get into that other vports.
I would like to have a toggle button to switch between vports when I am in the VPMAX window.
Message 18 of 26
steven-g
There has never been AFAIK, if it works on the mac system that's one up for mac users
Message 19 of 26
pendean
Community Legend
Community Legend
Ah, so you used to be on the MAC version? That's not an ability in the Windows versions of any AutoCAD variant, never has been.
Message 20 of 26
The image from a AutoCAD/AutoCAD LT 2008 book.
AutoCAD/AutoCAD LT 2010
AutoCAD/AutoCAD LT 2011
AutoCAD/AutoCAD LT 2012
AutoCAD/AutoCAD LT 2013
2013 is the last version that had this feature.
