I am a retired designer, 72, who now uses LT infrequently. Opened it an hour ago and non of the commands work!! Yes, it is paid for. Draw, Line, offset, none work. I need to have a drawing ready for Sunday 28 July!! Would someone help me, please. I am out of the technology curve so now out in the cold. Someone to talk to would be stellar! latitude18.3@gmail.com. 812-824-6164. John Cleveland
Let's try to fix your issue .
Imad Habash
try resetting AutoCAD to defaults: click here
@Anonymous wrote:
Thank you. Screen shots are not helpful because I cannot show you what
does not happen.
There may be clues to what is happening that you are missing and more experienced eyes will see them. You need to help others help you.
Thanks for trying to let us help you.
>> Thank you. Screen shots are not helpful because I cannot show you what does not happen.
NO ... you can . it's a screencast NOT screenshot . if you don't mind get back to my previous post and click the link to make a short screencast movie .
Imad Habash
Some of this might be a matter of adjusting settings. go into your OPTIONS menu and explore the various tabs. One thing to look for is your noun/verb selection to see how that's set. Another is right-click customization (under the User Preferences tab). There, you can set how the program responds to right-clicks under different circumstances.
A few other things I suspect are ORTHO vs POLAR, and how you enter coordinates and direction. Hit F1 and explore some of these things to brush up on working with them. Good luck!
