Hatch seems to be the problem
Message 1 of 21
Hi there,
I use ACAD Lt 2019. I have created a drawing with 3 or 4 hatch (dots) patterns in it. It's not particularly big (300kb)
I save it down to 2004 version (this is for my client's benefit) The drawing was purged prior to saving down.
When they try to open it on their machine that has an old ACAD 2006 version, it won't open.
If I remove the hatch patterns prior to saving it, the older version opens the drawing fine.
Is there a setting I've overlooked?
Any ideas why? thanks in advance.
Replies (20)
Message 2 of 21
Alfred.NESWADBA
if you change the pattern to anything else than DOTS, does it then work?
What happens on your system when you open the 2004-file, does the hatch show up?
>> it won't open
What message do you get?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 21
imadHabash
can we know if there is any kind of messages appear when it won't open ?
>> Any ideas why?
if they try to start with RECOVER command , any changes ?
Imad Habash
Message 4 of 21
Hi g
Weve tried with a soliad and dashed pattern. Same thing happens.
The dwg opens fine on 2019 but wont open on 2006
There are no messgaes. Its non responsive. Ive left it for 10 minutes and nothing happens.
Message 5 of 21
imadHabash
what about RECOVER command ?
Imad Habash
Message 6 of 21
Alfred.NESWADBA
Does this other workstation run out of memory?`Just not enough resources?
Can you upload such a dwg so I can try it with one of my older versions of AutoCAD?
- alfred -
Alfred NESWADBA
Message 7 of 21
We havent tried the recover command TBH.
Message 8 of 21
Dont know.
I attached the dwg.
Message 9 of 21
Alfred.NESWADBA
this drawing was not created with AutoCAD (or at least was sometimes edited with a non Autodesk product).
Next issue could be that you have set transparency values ... you know that AutoCAD 2004 does not support transparency?
- alfred -
Alfred NESWADBA
Message 10 of 21
Ignore the first attachment. This attachment is the correct one.
Message 11 of 21
Yes, it was created by a NON-Autodesk product, but that hasn't ever given me problems before. I didn't know about the transparency issue. I'll try altering that and see if it works.
Message 12 of 21
imadHabash
same message for both previous attachments ( another application ) !!
Imad Habash
Message 13 of 21
Alfred.NESWADBA
Same file again, no difference, same message about not trusted DWG-format.
BTW: I tried Autodesk LandDevelopment Desktop 2004 (which is based on AutoCAD 2004) ... the drawing opened well.
So it might be more an issue of the 2006 installation or the system itself (not enough resources).
- alfred -
Alfred NESWADBA
Message 14 of 21
RobDraw
Instead of saving as an older version, export it to see if that makes a difference.
Rob
Message 15 of 21
pendean
Community Legend
Community Legend
>>>...I use ACAD Lt 2019...<<<
Any good reason you are not using this tool to knock your files down properly to 2004dwg format
Message 16 of 21
I guess not. Is this a different type of save/convert, as opposed to, save as and changing the save as to older versions in the pull down menu?
Message 17 of 21
RobDraw
Yes, it is.
Rob
Message 18 of 21
Ah. Whats the diffence?
Message 19 of 21
RobDraw
It actually converts newer objects/features to be compatible with older versions. Saving as an older version does not.
Rob
Message 20 of 21
Oh. Thanks. That would explain many issues over the years!!😁🤔
