Hatch pattens, when rotated go from pattern to solid (only some of them)
CherylKrismer2316
CherylKrismer2316
Using LT 2024, a couple months ago I imported some custom hatch patterns, and they custom patterns plus some standard patterns (not all of them) won't rotate and keep the pattern.  They go from pattern to solid when rotated.  This is happening specifically with GOST_WOOD
If I go into .....AutocadLT2024/R30/enu/Support all I see is a file called infocentre.xml.  I have all hidden files turned on in control panel.
I am trying to figure out how to reload the standard hatch patterns, without resetting everything.
If I log on as another user, can I save the hatch patterns as a file and then reload them in the location noted above?
Any other ideas?
Replies (13)
paullimapa
Hatch patterns definitions are typically stored in a file that has an extension of .pat
Now it’s possible that they’re all in acadlt.pat. Since this is a text file, you can open it up with notepad and do a search for the name of the hatch patterns.
Paul Li
IT Specialist
@The Office
CherylKrismer2316
The file name for GOST_WOOD is in the acadtlt.pat file, but it doesn't explain why this pattern looses it's integrity when rotated and goes solid instead of pattern?
cadffm
only ONE file in this folder?
"all I see is a file"
Sebastian
paullimapa
Perhaps you can share your acadlt.pat file here for others to try. Also provide names of all the added custom patterns that exhibit this behavior
Paul Li
IT Specialist
@The Office
cadffm
One idea
You are talking about to rotate the Hatch object, not just to change the rotation of the pattern?
If so
rotate your object and change hatch ORIGIN to near to the hatch object.
For example, change hatch origin to the edge or center of the hatch.
Does it work again?
If not: change hatch scalefactor 2x
or 0.5x of the current value.
does it work now?
Sebastian
CherylKrismer2316
The file acadtlt.pat has all the standard hatch patterns in it, but not my custom patterns. I can see all my custom and standard hatch patterns in CAD when I am working. If I hatch an object with GOST_WOOD at 0.00° it looks fine. As soon as I rotate it 90° it goes to a solid colour and I can't fix it.
CherylKrismer2316
sorry, yes to clarify in 'hatch edit' I change the orientation by 90°, I don't rotate the hatch object.  Changing the scale doesn't change the density or affect how the hatch looks, it's definitely solid even though it started as a pattern
CherylKrismer2316
;; Copyright 2023 Autodesk, Inc. All rights reserved.
;; Use of this software is subject to the terms of the Autodesk license
;; agreement provided at the time of installation or download, or which
;; otherwise accompanies this software in either electronic or hard copy form.
;; Version 2.0
;; AutoCAD Hatch Patterns
;; Note: in order to ease migration of this file when upgrading
;; to a future version of AutoCAD, it is recommended that you add
;; your customizations to the User Defined Hatch Patterns section at the
;; end of this file.
;; Note: Dummy pattern description used for 'Solid fill'.
*SOLID, Solid fill
45, 0,0, 0,.125
*ANGLE, Angle steel
0, 0,0, 0,.275, .2,-.075
90, 0,0, 0,.275, .2,-.075
*ANSI31, ANSI Iron, Brick, Stone masonry
45, 0,0, 0,.125
*ANSI32, ANSI Steel
45, 0,0, 0,.375
45, .176776695,0, 0,.375
*ANSI33, ANSI Bronze, Brass, Copper
45, 0,0, 0,.25
45, .176776695,0, 0,.25, .125,-.0625
*ANSI34, ANSI Plastic, Rubber
45, 0,0, 0,.75
45, .176776695,0, 0,.75
45, .353553391,0, 0,.75
45, .530330086,0, 0,.75
*ANSI35, ANSI Fire brick, Refractory material
45, 0,0, 0,.25
45, .176776695,0, 0,.25, .3125,-.0625,0,-.0625
*ANSI36, ANSI Marble, Slate, Glass
45, 0,0, .21875,.125, .3125,-.0625,0,-.0625
*ANSI37, ANSI Lead, Zinc, Magnesium, Sound/Heat/Elec Insulation
45, 0,0, 0,.125
135, 0,0, 0,.125
*ANSI38, ANSI Aluminum
45, 0,0, 0,.125
135, 0,0, .25,.125, .3125,-.1875
;; The following hatch patterns AR-xxxxx
;; come from AEC/Architectural
*AR-B816, 8x16 Block elevation stretcher bond
0, 0,0, 0,8
90, 0,0, 8,8, 8,-8
*AR-B816C, 8x16 Block elevation stretcher bond with mortar joints
0, 0,0, 8,8, 15.625,-.375
0, -8,.375, 8,8, 15.625,-.375
90, 0,0, 8,8, -8.375,7.625
90, -0.375,0, 8,8, -8.375,7.625
*AR-B88, 8x8 Block elevation stretcher bond
0, 0,0, 0,8
90, 0,0, 8,4, 8,-8
*AR-BRELM, Standard brick elevation english bond with mortar joints
0, 0,0, 0,5.334, 7.625,-.375
0, 0,2.25, 0,5.334, 7.625,-.375
0, 2,2.667, 0,5.334, 3.625,-.375
0, 2,4.917, 0,5.334, 3.625,-.375
90, 0,0, 0,8, 2.25,-3.084
90, -0.375,0, 0,8, 2.25,-3.084
90, 2,2.667, 0,4, 2.25,-3.084
90, 1.625,2.667, 0,4, 2.25,-3.084
*AR-BRSTD, Standard brick elevation stretcher bond
0, 0,0, 0,2.667
90, 0,0, 2.667,4, 2.667,-2.667
*AR-CONC, Random dot and stone pattern
50, 0,0, 4.12975034,-5.89789472, 0.75,-8.25
355, 0,0, -2.03781207,7.37236840, 0.60,-6.6
100.45144446,0.59771681,-0.05229344,5.7305871,-6.9397673,0.63740192,-7.01142112
46.1842, 0,2, 6.19462554,-8.84684596, 1.125,-12.375
96.63563549,.88936745,1.86206693,8.59588239,-10.40964966,0.95610342,-10.5171376
351.18416399,0,2, 7.74327494,11.05855746, 0.9,-9.90000001
21, 1,1.5, 4.12975034,-5.89789472, 0.75,-8.25
326, 1,1.5, -2.03781207,7.37236840, 0.60,-6.6
71.45144474, 1.49742254,1.16448426, 5.7305871,-6.9397673, 0.6374019,-7.01142112
37.5, 0,0, 2.123,2.567, 0,-6.52,0,-6.7,0,-6.625
7.5, 0,0, 3.123,3.567, 0,-3.82,0,-6.37,0,-2.525
-32.5, -2.23,0, 4.6234,2.678, 0,-2.5,0,-7.8,0,-10.35
-42.5, -3.23,0, 3.6234,4.678, 0,-3.25,0,-5.18,0,-7.35
*AR-HBONE, Standard brick herringbone pattern @ 45 degrees
45, 0,0, 4,4, 12,-4
135, 2.828427125,2.828427125, 4,-4, 12,-4
*AR-PARQ1, 2x12 Parquet flooring: pattern of 12x12
90, 0,0, 12,12, 12,-12
90, 2,0, 12,12, 12,-12
90, 4,0, 12,12, 12,-12
90, 6,0, 12,12, 12,-12
90, 8,0, 12,12, 12,-12
90, 10,0, 12,12, 12,-12
90, 12,0, 12,12, 12,-12
0, 0,12, 12,-12, 12,-12
0, 0,14, 12,-12, 12,-12
0, 0,16, 12,-12, 12,-12
0, 0,18, 12,-12, 12,-12
0, 0,20, 12,-12, 12,-12
0, 0,22, 12,-12, 12,-12
0, 0,24, 12,-12, 12,-12
*AR-RROOF, Roof shingle texture
0, 0,0, 2.2,1, 15,-2,5,-1
0, 1.33,0.5, -1,1.33, 3,-0.33,6,-0.75
0, 0.5,0.85, 5.2,0.67, 8,-1.4,4,-1
*AR-RSHKE, Roof wood shake texture
0, 0,0, 25.5,12, 6,-5,7,-3,9,-4
0, 6,.5, 25.5,12, 5,-19,4,-6
0, 18,-.75, 25.5,12, 3,-31
90, 0,0, 12,8.5, 11.5,-36.5
90, 6,0, 12,8.5, 11.25,-36.75
90, 11,0, 12,8.5, 10.5,-37.5
90, 18,-0.75, 12,8.5, 11.5,-36.5
90, 21,-0.75, 12,8.5, 11.5,-36.5
90, 30,0, 12,8.5, 11,-37
*AR-SAND, Random dot pattern
37.5, 0,0, 1.123,1.567, 0,-1.52,0,-1.7,0,-1.625
7.5, 0,0, 2.123,2.567, 0,-.82,0,-1.37,0,-.525
-32.5, -1.23,0, 2.6234,1.678, 0,-.5,0,-1.8,0,-2.35
-42.5, -1.23,0, 1.6234,2.678, 0,-.25,0,-1.18,0,-1.35
*BOX, Box steel
90, 0,0, 0,1
90, .25,0, 0,1
0, 0,0, 0,1, -.25,.25
0, 0,.25, 0,1, -.25,.25
0, 0,.5, 0,1, .25,-.25
0, 0,.75, 0,1, .25,-.25
90, .5,0, 0,1, .25,-.25
90, .75,0, 0,1, .25,-.25
*BRASS, Brass material
0, 0,0, 0,.25
0, 0,.125, 0,.25, .125,-.0625
*BRICK, Brick or masonry-type surface
0, 0,0, 0,.25
90, 0,0, 0,.5, .25,-.25
90, .25,0, 0,.5, -.25,.25
*BRSTONE, Brick and stone
0, 0,0, 0,.33
90, .9,0, .33,.5, .33,-.33
90, .8,0, .33,.5, .33,-.33
0, .9,.055, .5,.33, -.9, .1
0, .9,.11, .5,.33, -.9, .1
0, .9,.165, .5,.33, -.9, .1
0, .9,.22, .5,.33, -.9, .1
0, .9,.275, .5,.33, -.9, .1
*CLAY, Clay material
0, 0,0, 0,.1875
0, 0,.03125, 0,.1875
0, 0,.0625, 0,.1875
0, 0,.125, 0,.1875, .1875,-.125
*CORK, Cork material
0, 0,0, 0,.125
135, .0625,-.0625, 0,.35355339, .176776696,-.176776696
135, .09375,-.0625, 0,.35355339, .176776696,-.176776696
135, .125,-.0625, 0,.35355339, .176776696,-.176776696
*CROSS, A series of crosses
0, 0,0, .25,.25, .125,-.375
90, .0625,-.0625, .25,.25, .125,-.375
*DASH, Dashed lines
0, 0,0, .125,.125, .125,-.125
*DOLMIT, Geological rock layering
0, 0,0, 0,.25
45, 0,0, 0,.70710678,.353553390593273762200422181,-.707106781186547524400844362
*DOTS, A series of dots
0, 0,0, .03125,.0625, 0,-.0625
*EARTH, Earth or ground (subterranean)
0, 0,0, .25,.25, .25,-.25
0, 0,.09375, .25,.25, .25,-.25
0, 0,.1875, .25,.25, .25,-.25
90, .03125,.21875, .25,.25, .25,-.25
90, .125,.21875, .25,.25, .25,-.25
90, .21875,.21875, .25,.25, .25,-.25
*ESCHER, Escher pattern
60, 0,0, -.6,1.039230484, 1.1,-.1
180, 0,0, -.6,1.039230484, 1.1,-.1
300, 0,0, .6,1.039230484, 1.1,-.1
60, .1,0, -.6,1.039230484, .2,-1
300, .1,0, .6,1.039230484, .2,-1
60, -.05,.08660254, -.6,1.039230484, .2,-1
180, -.05,.08660254, -.6,1.039230484, .2,-1
300, -.05,-.08660254, .6,1.039230484, .2,-1
180, -.05,-.08660254, -.6,1.039230484, .2,-1
60, -.4,0, -.6,1.039230484, .2,-1
300, -.4,0, .6,1.039230484, .2,-1
60, .2,-.346410161, -.6,1.039230484, .2,-1
180, .2,-.346410161, -.6,1.039230484, .2,-1
300, .2,.346410161, .6,1.039230484, .2,-1
180, .2,.346410161, -.6,1.039230484, .2,-1
0, .2,.173205081, -.6,1.039230484, .7,-.5
0, .2,-.173205081, -.6,1.039230484, .7,-.5
120, .05,.259807621, .6,1.039230484, .7,-.5
120, -.25,.08660254, .6,1.039230484, .7,-.5
240, -.25,-.08660254, .6,1.039230484, .7,-.5
240, .05,-.259807621, .6,1.039230484, .7,-.5
*FLEX, Flexible material
0, 0,0, 0,.25, .25,-.25
45, .25,0, .176776695296,.176776695296, .0625,-.2285533906,.0625,-.353553390593
*GOST_GLASS,glass material
45, 0, 0, 6, -6, 5, -7
45, 2.121320, 0, 6, -6, 2, -10
45, 0, 2.121320, 6, -6, 2, -10
*GOST_WOOD,wood material
90, 0, 0, 0, -6, 10, -2
90, 2, -2, 0, -6, 6, -1.5, 3, -1.5
90, 4, -5, 0, -6, 10, -2
*GOST_GROUND,ground
45, 0, 0, 10, -10, 20
45, 3, 0, 10, -10, 20
45, 6, 0, 10, -10, 20
*GRASS, Grass area
90, 0,0, .707106781,.707106781, .1875,-1.226713563
45, 0,0, 0,1, .1875,-.8125
135, 0,0, 0,1, .1875,-.8125
*GRATE, Grated area
0, 0,0, 0,.03125
90, 0,0, 0,.125
*GRAVEL,Gravel pattern
228.012787504,.72,1.0,12.0413651692039,.0743294146632,.134536,-13.3190880470737
184.969740728,.63,.90,-12.0415166747131,.0433148081592,.230868,-22.xxx-xxxxxxxx
132.510447078,.40,.88,-14.8659418273816,.061429511683,.162788,-16.1160325960997
267.273689006,.01,.63,-20.0249279039043,.0475651493827,.210238,-20.813558041629
292.833654178,0.0,.42,-12.9999095019474,.048507125026,.206155,-20.4093731280883
357.273689006,.08,.23,-20.0249279039043,.0475651493827,.210238,-20.813558041629
37.6942404667,.29,.22,-16.4011800288558,.0359675000664,.278029,-27.524848548916
72.2553283749,.51,.39,23.0867613281116,.0380969659053,.262488,-25.9863214968134
121.429565615,.59,.64,15.2642639131074,.047404546271,.210950,-20.884073109729
175.236358309,.48,.82,-11.0450488205478,.083045479801,.240832,-11.8007625787923
222.397437798,.24,.84,16.2787889313724,.0321080648114,.311448,-30.8333750047949
138.814074834,1.0,.62,9.2190645101588,.0940720868851,.106301,-10.5238448127347
171.469234390,.92,.69,-13.1528534931484,.0494468176315,.202237,-20.021511416157
225.000000000,.72,.72,0.7071067811865,.7071067811865,.141421,-1.2727925623731
203.198590514,.65,.84,-5.3835637472478,.1313064328928,.076158,-7.5396151058639
291.801409486,.58,.81,-3.156820749011,.185695338158,.107703,-5.2774618071345
30.9637565321,.62,.71,3.6014702879928,.1714985851408,.174929,-5.6560228948453
161.565051177,.77,.80,-2.2135943621183,.3162277660138,.126491,-3.0357866601684
16.3895403340,0.0,.81,10.4401539876873,.0564332648047,.177200,-17.5428451466694
70.3461759419,.17,.86,-11.7045066155395,.0672672793901,.148661,-14.717407747319
293.198590514,.77,1.0,-5.3835637472478,.1313064328928,.152315,-7.4634581058639
343.610459666,.83,.86,-10.4401539876873,.0564332648047,.177200,-17.542845146669
339.443954780,0.0,.19,-5.3838927710229,.117041147157,.170880,-8.3731237453175
294.775140569,.16,.13,-12.0828441168135,.0698430296124,.143178,-14.174643063276
66.8014094864,.78,0.0,5.3835637472487,.1313064328552,.152315,-7.4634581058639
17.3540246363,.84,.14,-13.6013396869991,.0596549986364,.167631,-16.xxx-xxxxxxxx
69.4439547804,.29,0.0, -5.383892771022,.1170411471946,.085440,-8.4585637453175
101.309932474,.72,0.0,4.1184388379018,.1961161351396,.050990,-5.0480295135928
165.963756532,.71,.05,-3.1529631254726,.2425356250323,.206155,-3.9169506256177
186.009005957,.51,.10,-10.0497393137326,.0523423921723,.191050,-18.9139231745428
303.690067526,.62,.62,-2.2188007849008,.2773500981134,.144222,-3.4613292754640
353.157226587,.7,.5,17.1171966955143,.0397150736497,.251794,-24.9275626240283
60.9453959009,.95,.47,-8.0616726575653,.0971285862325,.102956,-10.192674140987
90, 1,.56, 1.000,1.000, .06,-.940
120.256437164,.49,.13,-8.0619364083848,.0719815751411,.138924,-13.7535199894498
48.0127875042,.42,.25,12.0413651692041,.0743294146212,.269072,-13.1845520470737
0, .60, .45, 1, 1, .26,-.74
325.304846469,.86,.45,12.2063917682497,-.063245553253,.158114,-15.653274300842
254.054604099,.99,.36,4.1208169184605,.1373605639542,.145602,-7.1345078892805
207.645975364,.95,.22,21.4708691170287,.0421824539631,.237065,-23.4694741822594
175.426078740,.74,.11,13.0383438432524,.039872611164,.250799,-24.8290734079689
*HEX, Hexagons
0, 0,0, 0,0.21650635094610966169093079268823, .125,-.25
120, 0,0, 0,0.21650635094610966169093079268823, .125,-.25
60, .125,0, 0,0.21650635094610966169093079268823, .125,-.25
*HONEY, Honeycomb pattern
0, 0,0, .1875,0.10825317547305483084546539634412, .125,-.25
120, 0,0, .1875,0.10825317547305483084546539634412, .125,-.25
60, 0,0, .1875,0.10825317547305483084546539634412, -.25,.125
*HOUND, Houndstooth check
0, 0,0, .25,.0625, 1,-.5
90, 0,0, -.25,.0625, 1,-.5
*INSUL, Insulation material
0, 0,0, 0,.375
0, 0,.125, 0,.375, .125,-.125
0, 0,.25, 0,.375, .125,-.125
;; Hatch Pattern Definition related to ISO/DIS 12011 line types
;; (Width * 5 = Distance between lines)
;; The size of the line segments related to the ISO/DIS 12011 linetypes
;; define the following hatch pattern.
;; The pen width of 1 mm is the base of the definition. To use them with
;; the other ISO/DIS 12011 predefined pen widths, the line has to be scaled
;; with the appropriate value (e.g. pen width 0,5 mm -> ltscale 0.5).
*ACAD_ISO02W100, dashed line
0, 0,0, 0,5, 12,-3
*ACAD_ISO03W100, dashed space line
0, 0,0, 0,5, 12,-18
*ACAD_ISO04W100, long dashed dotted line
0, 0,0, 0,5, 24,-3,.5,-3
*ACAD_ISO05W100, long dashed double dotted line
0, 0,0, 0,5, 24,-3,.5,-3,.5,-3
*ACAD_ISO06W100, long dashed triplicate dotted line
0, 0,0, 0,5, 24,-3,.5,-3,.5,-6.5
0, 0,0, 0,5, -34,.5,-3
*ACAD_ISO07W100, dotted line
0, 0,0, 0,5, .5,-3
*ACAD_ISO08W100, long dashed short dashed line
0, 0,0, 0,5, 24,-3,6,-3
*ACAD_ISO09W100, long dashed double-short-dashed line
0, 0,0, 0,5, 24,-3,6,-3,6,-3
*ACAD_ISO10W100, dashed dotted line
0, 0,0, 0,5, 12,-3,.5,-3
*ACAD_ISO11W100, double-dashed dotted line
0, 0,0, 0,5, 12,-3,12,-3,.5,-3
*ACAD_ISO12W100, dashed double-dotted line
0, 0,0, 0,5, 12,-3,.5,-3,.5,-3
*ACAD_ISO13W100, double-dashed double-dotted line
0, 0,0, 0,5, 12,-3,12,-3,.5,-6.5
0, 0,0, 0,5, -33.5,.5,-3
*ACAD_ISO14W100, dashed triplicate-dotted line
0, 0,0, 0,5, 12,-3,.5,-3,.5,-6.5
0, 0,0, 0,5, -22,.5,-3
*ACAD_ISO15W100, double-dashed triplicate-dotted line
0, 0,0, 0,5, 12,-3,12,-3,.5,-10
0, 0,0, 0,5, -33.5,.5,-3,.5,-3
;; end of ACAD_ISO hatch pattern definition
*LINE, Parallel horizontal lines
0, 0,0, 0,.125
*MUDST, Mud and sand
0, 0,0, .5,.25, .25,-.25,0,-.25,0,-.25
*NET, Horizontal / vertical grid
0, 0,0, 0,.125
90, 0,0, 0,.125
*NET3, Network pattern 0-60-120
0, 0,0, 0,.125
60, 0,0, 0,.125
120, 0,0, 0,.125
*PLAST, Plastic material
0, 0,0, 0,.25
0, 0,.03125, 0,.25
0, 0,.0625, 0,.25
*PLASTI, Plastic material
0, 0,0, 0,.25
0, 0,.03125, 0,.25
0, 0,.0625, 0,.25
0, 0,.15625, 0,.25
*SACNCR, Concrete
45, 0,0, 0,.09375
45, .066291261,0, 0,.09375, 0,-.09375
*SQUARE,Small aligned squares
0, 0,0, 0,.125, .125,-.125
90, 0,0, 0,.125, .125,-.125
*STARS, Star of David
0, 0,0, 0,.216506351, .125,-.125
60, 0,0, 0,.216506351, .125,-.125
120, .0625,.108253176, 0,.216506351, .125,-.125
*STEEL, Steel material
45, 0,0, 0,.125
45, 0,.0625, 0,.125
*SWAMP, Swampy area
0, 0,0, .5,.866025403, .125,-.875
90, .0625,0, .866025403,.5, .0625,-1.669550806
90, .078125,0, .866025403,.5, .05,-1.682050806
90, .046875,0, .866025403,.5, .05,-1.682050806
60, .09375,0, .5,.866025403, .04,-.96
120, .03125,0, .5,.866025403, .04,-.96
*TRANS, Heat transfer material
0, 0,0, 0,.25
0, 0,.125, 0,.25, .125,-.125
*TRIANG, Equilateral triangles
60, 0,0, .1875,.324759526, .1875,-.1875
120, 0,0, .1875,.324759526, .1875,-.1875
0, -.09375,.162379763, .1875,.324759526, .1875,-.1875
*ZIGZAG, Staircase effect
90, .125,0, .125,.125, .125,-.125
;; User Defined Hatch Patterns
;; Add any hatch patterns that you define to this section of
;; the file to ensure that they migrate properly when
;; upgrading to a future AutoCAD version. If duplicate hatch
;; patterns are found in this file, items in the User Defined
;; Hatch Patterns section take precedence over patterns that
;; appear earlier in the file.
pendean
Community Legend
Community Legend
Show us: share your problematic hatches in that DWG file, and point to them.
Sometimes what you see is not a 'solid' hatch, just a loss of scale: LIST or PROPERTIES command to confirm.
If they are SOLID hatch pattern name, then someone somewhere changed them, AutoCAD holds on to patterns already in the file no matter who opens them.
paullimapa
In your reply to me you stated
“The file name for GOST_WOOD is in the acadtlt.pat file,”
But then your reply to @cadffm you stated something else
The file acadtlt.pat has all the standard hatch patterns in it, but not my custom patterns”
So which is it?
Paul Li
IT Specialist
@The Office
CherylKrismer2316
I opened two new files, the standard template from LT2024 and our own internal template. I tried to recreate the issue in both those files and the GOST_WOOD works just fine in both orientations, at all scales. I rebooted and opened the file I was working in and now the problem no longer happens. This is really frustrating because it's not the first time I have had this issue in the past few months, but I think resolution will have to wait until I can recreate it and walk it through here again. It wasn't a scale issue.
CherylKrismer2316
GOST_WOOD is a preinstalled Autocad hatch pattern, it is not a custom hatch pattern that I imported.
pendean
Community Legend
Community Legend
...I rebooted and opened the file I was working in and now the problem no longer happens....
often that should be the first thing you try when the program starts acting weird for no reason.
...will have to wait until I can recreate it and walk it through here again. It wasn't a scale issue.
Not likely to occur again unless you store your PAT files somewhere LT2024 losses access because it went offline.
You are running this updated version, yes?
