Hatch linetype not displaying
MartynCowley3208
Message 1 of 13
MartynCowley3208
I am using a User-defined hatch, doubled to produce squares; the layer linetype is Hidden but the hatch lines appear solid regardless of either the Linetype scale setting or the object Linetype scale.
Ordinary Lines or Polylines on the same layer appear correctly.
Have I missed something?
Replies (12)
Message 2 of 13
h_s_walker
Can you post the drawing containing the hatch or a blank drawing containing the hatch as how you want it.
Howard Walker
Left Handed and Proud
Message 3 of 13
MartynCowley3208
The attached picture shows part of the drawing with the hatch (representing floor tiles 600mm square) on a layer with Linetype 'Hidden'; the rectangle to the left is on the same layer. Both have object linetypescale = 1.
Global linetype scale factor = 25 (viewport scale is 1:50)
Paperspace units for scaling is off
I have changed the linetypescale for the hatch up and down from 1 by orders of magnitude with no change.
john.vellek has embedded your image(s) for clarity
Message 4 of 13
sthompson1021
Linetypes, do not have anything to do with a hatch pattern. The lines that form the grid are generated by the code in the .pat file. They are not assigned a linetype within the .pat file.
Message 5 of 13
MartynCowley3208
That certainly wasn't the case in previous versions (I am using 2019), hatch patterns always adopted the linetype as if they were 'Byblock', whether by Layer or individually.
Undoubtedly you could define a hatch by specifying particular segments of the pattern, but the line elements would take the linetype assigned by Layer or Properties
Message 6 of 13
MartynCowley3208
I have just noted the following in the Help files:
Relative to Paper Space
Scales the hatch pattern relative to paper space units. This allows you to display hatch patterns at a scale that is appropriate for your named layout. This option is available only from a named layout.
However, the button in the Hatch Properties tab of the ribbon is greyed out, even though the Layout is named 'A3H'.
The drawing I tried this in displays the hatch with the Layer Linetype in version 2018 and earlier, but not 2019.
(The 'Relative to Paper Space' button is greyed out in 2018 too.)
Message 7 of 13
john.vellek
Hi @MartynCowley3208,
Can you share a sample file with your hatch pattern in it? I would like to test in AutoCAD 2017, 2018, and 2019 to see if there are any differences.
I tested by adding a user-defined hatch (doubled) on a layer with hidden2 linetype and it behaves the same in 2018 and 2019 and does not apply a linetype to the hatch.  Perhaps i am doing something different than your method.
John Vellek
Message 8 of 13
MartynCowley3208
Attached is a drawing sample showing a hatch pattern with Linetype 'ByLayer', Layer (RaisedFloor) with Linetype 'Hidden', Global scale factor = 20, object linetype scale = 1.
In LT2015 (and 2018) the hatch appears with the correct line display, in LT2019 the lines appear continuous.
Message 9 of 13
john.vellek
Check the HPLINETYPE variable to see if is On.
John Vellek
Message 10 of 13
MartynCowley3208
HPLINETYPE seems to have slipped past me - not something I have come across before; is it a relatively new Variable, or simply that it has been ON by default in previous versions?
Message 11 of 13
cadffm
Always default off, since starting 4 years ago in version 2015.
Sebastian
Message 12 of 13
dcapuya
Community Visitor
Community Visitor
thanks champ! You're the MVP.
Message 13 of 13
zimmerroo
John -
That command "HPLINETYPE" is exactly what we were all looking for! Thank you so much!!!
