flatten command and add spline fit point
orendothan
Message 1 of 12
orendothan
I recently switched from the full version to LT. Two commands that I am missing are:
How to add a vertex (fit point) to a pline or spline. I used to be able to hover over a fit point and add. It doesn;t seem to work on my current version. Any idea why ?
Flatten command doesn't seem to be available in LT.
Is there a work around ?
Replies (11)
Message 2 of 12
paullimapa
For Flatten review recent thread here:
Solved: Flatten and Express Tools seem to be missing - Autodesk Community
Paul Li
IT Specialist
@The Office
Message 3 of 12
pendean
Community Legend
Community Legend
@orendothan wrote:
...Flatten command doesn't seem to be available in LT.
Nope. All part of the discount that is the LT version.
If you only need to move content from Z>0 to Z=0, there are free LISP routines everywhere you can use if you are running LT2024 or LT2025 (older LT versions have no LISP ability, you'll need to use PROPERTIES command).
HTH
Message 4 of 12
orendothan
ok thanks I'll try the lisp
Message 5 of 12
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
Message 6 of 12
cadffm
Grips should work.
Select a grip (make grip hot / click inside a grip)
Right-Click to open the context menu.
Are the options available?
Multifunctional grips also.
Make sure MultiFunctionalGrip is on (3)
Test it with a polyline, created by command rectang
Sebastian
Message 7 of 12
orendothan
how do I change MultiFunctionalGrip  ?
Message 8 of 12
orendothan
when I hover above the grip point and it turns red, the menu for adding a grip point doesn't appear. Works on other computers not on this one for some reason ?
Message 9 of 12
cadffm
Hovering
https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-A88576CB-7CDD-4DC4-819C-EA0F892E72CB
Grip shouldn't be red by hovering, just by left click (aka hotgrip).
Then rightclick to open the contextmenu
Sebastian
Message 10 of 12
cadffm
Your shape is not what i mentioned for a test. I said, command: Rectang!
Sebastian
Message 11 of 12
pendean
Community Legend
Community Legend
@orendothan wrote:
when I hover above the grip point and it turns red, the menu for adding a grip point doesn't appear....
it must turn green and you need to turn this on
if the grip turns red, then you select it to move, so not grips menu appear.
Message 12 of 12
orendothan
works !!!
Thank you, that was brilliant. 😍
