Can anyone help me???? I have been givin a drawing that I am unable to print dark enough with out my layers in some areas becomeing way to thick and I was wondering if it is at all possible to select the whole drawing and just reset the line weights to a default setting with out having to go layer by layer.
Solved by Charles_Shade. Go to Solution.
Do you use a plot style table when plotting? If yes, is it screen-color based (CTB) or is it STB?
If you don't, explain in mode detail?
SELECT <Enter>
All <Enter>
CHPROP <Enter>
LW <Enter>
(whatever you want)
<Enter>
or
CHPROP <>
All <>
LW <>
(whatever you want)
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
