fillet command problem
Message 1 of 28
Long time user, all of the sudden, fillet command does not work.  I did lots of googling, and found PICKADD command.  I changed the variables (0, 1 and 2), but that didn't work.  Lines are in the same plane.  If I pick a radius instead of just 90 degree fillet, it will draw the arc, but it won't connect the lines.   So you have two perpendicular lines with a floating arc.  Fillet does work if I want to fillet two parallel lines, (which I never do).  Any thoughts on what might be happening?  Oh, I did discover that it will fillet if I select the first line, then hit SHIFT select for the second.  That's the only way it works, but that's not how I've been doing it for 25 years.
Fillet is something I use constantly.  HELP!
Replies (27)
Message 21 of 28
Thanks for that info.. help me to regain my sanity
Message 22 of 28
kamlasmwm
Observer
Observer
Oh... Boris 😅😅😅 hundreds of working time saved brother. Thanks a lot.
was yet to give up and manually cut all the remaining lines. 😁😁. I love problems like these. This is when we learn outside the box.
thanks Br. Boris
Message 23 of 28
This did it for me.  Thank you!
Message 24 of 28
-deleted-
Message 25 of 28
Yes you can set it to No Trim all the time by setting the trimmode variable to 0.  Then the fillet command doesn't fillet lines together.  Don't ask me why you would want that though?
Message 26 of 28
kaylaE3NQG
If the "no trim" setting in fillet doesn't work.
Go to the Viewcube and click "Top" this will set the xyz coordinates to (0,0,0).
The reason it wont fillet between perpendicular lines is because one of the lines "Z" access is not at 0.
(Version 2020)
Message 27 of 28
r.savage1776
Community Visitor
Community Visitor
Thanks!!!
Message 28 of 28
trebacz_004
Community Visitor
Community Visitor
Thanks A LOT!
