fillet command problem
Message 1 of 28
Long time user, all of the sudden, fillet command does not work.  I did lots of googling, and found PICKADD command.  I changed the variables (0, 1 and 2), but that didn't work.  Lines are in the same plane.  If I pick a radius instead of just 90 degree fillet, it will draw the arc, but it won't connect the lines.   So you have two perpendicular lines with a floating arc.  Fillet does work if I want to fillet two parallel lines, (which I never do).  Any thoughts on what might be happening?  Oh, I did discover that it will fillet if I select the first line, then hit SHIFT select for the second.  That's the only way it works, but that's not how I've been doing it for 25 years.
Fillet is something I use constantly.  HELP!
Replies (27)
Message 2 of 28
jim
I have attempted to replicate your problem and 2016LT is working normally for me. Which version are you having this problem with? I hate issues like that when for an unexplained reason an old usefull tool stops fuctioning the way you know it should.
JimH
Message 3 of 28
It's VERY odd, I am using autocadLT 2012. If you draw two perpendicular lines, and try to fillet, an X will appear at the intersection point, but it will not extend the two lines. I think I mentioned it will draw an arc if I set radius to 12" for example, but it will only draw the arc, it won't extend the two lines. Never seen this before. I've rebooted my computer. Tried the command on various old drawing where the command worked in the past, but nothing works.
Thanks for checking into this!
Sent from my iPhone
Message 4 of 28
bob_mpc
You have accidentaly clicked on "NO TRIM" option of the command.
Set it to TRIM the lines.
Boris
AutoCad LT 2021.1.1
Message 5 of 28
Hallelujah! Never in all my years have I had that problem. Thanks Boris!
Message 6 of 28
How do I set to No Trim?
Message 7 of 28
type FILLET command, then type TRIM, you should see the two options pop up, TRIM or NO TRIM, you can then select which you prefer.  If TRIM is selected it will connect two non-parallel lines.  Hope that works for you.
Message 8 of 28
pendean
Community Legend
Community Legend
BTW there is no way to set it to NO TRIM all the time BUT you can permanently edit the macro behind the button you lick to do so. Would you like to do that?
Message 9 of 28
I ensured the setting is on TRIM and now when I pick the 2nd line to fillet, a message appears saying the line is not coplanar.
Please advise,
Brett McGowan
Vantage Foods
Ph: (717) 317-5831
Cell: (717) 743-0487
Message 10 of 28
pendean
Community Legend
Community Legend
"coplanar' means one of the lines as a Z setting other than 0.000000000. You need to flatten your objects, use PROPERTIES command.
Remember, all objects in AutoCAD/LT have an X, Y and Z setting: since TRIM is a 2D function all of your objects (and both ends of a line object) must be at Z=0.00000000
Message 11 of 28
Draw 2 lines perpendicular to each othe and select fillet command and give fillet radius and now select first line and go on second line and right click now select radius and select second line ...
Lines will take fillet
Message 12 of 28
I can not get "fillet" command back. I have reloaded acad program and ACAD.cuix several times, but the command is not being recognized.  How do I get the "fillet" command back into the program?
Message 13 of 28
pendean
Community Legend
Community Legend
What is the exact error that you get at the commandline?
Message 14 of 28
First go to option and select profile.Then click Reset(R).
My problem solved by this way and i’m using 2014 Autocad.
I hope that’ll work 😊
Message 15 of 28
that command not working
but use this FLATTEN command this is much use full
type FLATTEN then select that two line and enter
then u r AutoCAD will be refresh then use fillet command that will be work
Message 16 of 28
This doesn't work for me..
Message 17 of 28
cadffm
And now?
Perhaps you share a sample dwg file and we can see and explain the problem, incl. the solution THEN 😉
Sebastian
Message 18 of 28
I have a problem with the fillet command. When I typing "F" the command that active is FASTSEL but in the alias commands the letter assigned to FILET is F.
Message 19 of 28
cadffm
1. Check the right pgp again, from bottom to top, the first hit (if there are several) applies!
Unfortunately, not everyone at Adesk understood that, but we, the users, should know that.
2. When you type in F (only F, no enter hit), check your commandline.
What do you see in this moment in the commandline?
If "FASTSEL", you can use [<-] key or/abd have to learn more about the commandline feature "automatic completion"
http://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-BB0C3E79-66AF-4557-9140-D31B4CF3C9CF
Sebastian
Message 20 of 28
jcarlson
Community Visitor
Community Visitor
This worked for me.
Thank you!
