AutoCAD LT Forum
Files Formats
3 REPLIES 3
t_leis
450 Views, 3 Replies
Files Formats
With autocad LT can I import a PDF file scale it and export it as a DXF?
3 REPLIES 3
pendean
in reply to: t_leis
LT2017 and LT2018 can convert PDF to DWG which you can them convert to DXF, if and only if the PDF is a vector and not a raster type http://visual-integrity.com/faqs/spotting-difference-vector-raster-pdf/
Otherwise, no, AutoCAD is not designed to convert pdf to dxf.
Emmsleys
in reply to: t_leis
Hi @t_leis
Welcome to the Autodesk Community!
This depends on what version of AutoCAD LT for any releases earlier than 2017 the answer is no.
If you are using an older version of AutoCAD you could use the link below for suggested workarounds.
Best PDF to DWG converter
If you are using AutoCAD LT 2017 or 2018. You could look over the following.
To Work with Importing PDF Data
Post back if you have any other questions or need additional suggestions.
Sarah Emmsley
Technical Support Specialist
Emmsleys
in reply to: t_leis
I'm following up on my previous post if you have any questions or found a workaround post back with any new updates
If you still need help or have questions I'll be more than happy to help.
Thanks.
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
Technology Administrators
