AutoCAD LT Forum
File not open Loading modeler DLLS
12 REPLIES 12
Message 1 of 13
MCristinaP
1010 Views, 12 Replies
I'm trying open a .dwg file but the program stop and i have to shut down with ctrl+alt+canc.
This error is about some files not everyone.
I tried open these files with dwg laucher or a new Autocad version but i fail.
This is the autocad 2021 message.
Someone can help me ?
12 REPLIES 12
Message 2 of 13
steven-g
in reply to: MCristinaP
Is this a new install of AutoCAD (might need a repair)
Or is it just one file that shows this error in which case can you post that file here so we can check it?
Message 3 of 13
steven-g
in reply to: steven-g
Which version of AutoCAD are you using and does it have the latest update
Message 4 of 13
MCristinaP
Until yesterday i used update 2020 autodesk LT , now i have the 2021 version.
The error is the same.
Message 5 of 13
steven-g
Then can you post a file for someone to look at to see if the problem is with the files?
Message 6 of 13
pendean
>>>...This error is about some files not everyone....<<<
You need to fix those files, not just change AutoCAD versions and hope it will automagically work.
There are many ways to fix files, here is a list you need to go through starting with RECOVER command https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
Message 7 of 13
MCristinaP
i cannot because privacy
Message 8 of 13
MCristinaP
in reply to: pendean
Ii try to recover but it doesn't work .
Then the program stop.
Message 9 of 13
pendean
The link I provided also included other things to try, give them a shot too.
What is your LT version? What variant of AutoCAD where the files created in? Not LT for sure if you are having so much trouble.
Message 10 of 13
MCristinaP
I made it with autocad 2020 LT, i have only this one.
I would try the other  options solution but i can't open the files to type the command.
Message 11 of 13
pendean
Can you share that DWG file here for us to try?
Message 12 of 13
MCristinaP
I'm sorry no for privacy. My boss try to open the file with Mac without any problems
Message 13 of 13
pendean
Have the boss fix the file there, send them the link I shared above.
Technology Administrators
