I am not able drag and drop .dwg file to a flash drive. a dialog box says 1 interrupted Action: "file has properties that can't be copied to the new location". However, I can 'save as' to the flash drive, but am prompted to 'update references w/ relative paths'. So I'm wondering if this is the issue?? thanks, Greg
Solved by pendean. Go to Solution.
