File names changing to folder name
Message 1 of 12
I keep a shortcut to my drawings folder on my desktop.  Ever since I had AutoCAD 2017LT installed, when I am saving a new drawing and click on the shortcut on my desktop, the file name changes to the folder name.  I have never seen this before and could use some help figuring it out.
Replies (11)
Message 2 of 12
john.vellek
HI @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
This is indeed unusual. Is it possible to prepare a Screencast video for me that shows this in action?
John Vellek
Message 3 of 12
http://autode.sk/2tG9Vkm
I made this a private screencast.
Hopefully I can share it.
I haven't tried this before.
Sheldon
Message 4 of 12
pendean
Community Legend
Community Legend
You have to make it "public": private means only you can see it.
What icons are you clicking on when OPEN command's pop-up appears?
Message 5 of 12
Thanks, I am very new to this.  I've made it public now.
Message 6 of 12
h_s_walker
It's the shortcut which is doing it. If you don't select the shortcut and just select a directory as normal the file name will not change
Howard Walker
Left Handed and Proud
Message 7 of 12
Yes, you are correct, but why does this only happen with AutoCAD files?
When I save other files the same way, there is no problem.
Is there a setting I can change to stop this from happening?
Navigating to this folder without a shortcut is very time consuming.
Message 8 of 12
pendean
Community Legend
Community Legend
No setting: this is why Autodesk provides this sidebar for you to drop your folder shortcuts into so you can avoid the issue:
Message 9 of 12
john.vellek
Hi @Anonymous,
Perhaps it is worth rebuilding your shortcuts. I use shortcuts on my desktop without any issue.
How do you make your shortcut?
John Vellek
Message 10 of 12
Thank you Dean.  I added the folder to the Places list and it seems to work just fine.  Fewer clicks as well.Smiley Very Happy
Message 11 of 12
John,
Thanks for your assistance.
I went with Deans solution and it worked very well.
Message 12 of 12
pendean
Community Legend
Community Legend
Glad it worked: you can also remove icons in that sidebar you do not want, as wel as rearrange the ones you add if needed.
