Hi Guys,
My drawings are in millimetres but I need to show the lengths of the fire escapes in meters. I was thinking of using fields for it. Which is working well. but I can't find how to change it from mm to m unless I change the whole drawing units.
Is it possible?
thanks
Solved by leticia.campanelli. Go to Solution.
never mind...
I found it...conversion factor in additional format.
if there is another way please let me know.
Go into the field dialog, setup the field - object - length ...and open your eyes.
Is there an option for [additional format] ?
If yes, 1meter is 0.001*Millimeter or Millimeter/1000
If you can not figured out, upload a dwg with ONE fire escapes and your field(what showing the length in millimeters.
Sebastian
That's it.
Sebastian
