Facing trouble while import layout from Template.
10:38 PM
if you are facing trouble while importing layout using from template option, and when you access the required folder (in which drawings are saved) its giving status that this folder is empty, then check the file type option where you click for ope file if it is on Drawing Template(*.dwt) then change it into Drawing (*.dwg)
All drawings will show there in folder now select your required one.
