I got a question; working AutoCad LT for some years now, but in this version, strangely my status bar is getting smaller and smaller and there seems no way to increase it and get it back to the original proportions; does anybody have an idea?
Solved by pendean. Go to Solution.
Hi Dean,
Thank you for your reply but the problem seems to be slightly different: the icons on the status bar were fine, also the width of the status bar is still fine; it's just that the hight of it is so small, I can hardly use it anymore; normally you can drag it so it becomes bigger, but it seems I can get it only wider, not higher....
Thanks in advance for your help!
Kind regands,
Lukas van de Vrande
I've the same problem my status bar is half the hight it should be. Tried the reset pallets trick but this opens a new session of AutoCAD with the same proplem. I'm using AutoCADLT 2015 on a MacBook Pro (Retina, 15 inch, medio 2014). I already searched the AutoCAD for Mac Forum wiht no luck.
Is there any solution to this problem i've missed?
Kind regards,
Patrick Middelkoop
If I click the link I get the attached screen, not an answer. If I search the Mac forum there is no working answer there.
Click on the first link at the top of the page, then ask by starting a new thread: this here is the wrong forum for MAC products.
