Exporting Text to Excel in Autocad LT 2024
PaulED3MQ
PaulED3MQ
Hi, Is there a way to export all the text or Mtext into an excel format?
I need to do a comparison on a lot of numbers from the drawing to see if there are any duplicates. Using excel I could find this out quickly.
pendean
Community Legend
Community Legend
LT versions of AutoCAD lack the built-in tools needed, but you can check out this alternative method posted on this page from Autodesk https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-bulk-export...!
PaulED3MQ
Ok No problem. I thought i saw that AutoCAD 24 had moved on a little in the way of this. Thanks for the link.
