Export Layout to Model - Batch
scottspeig
scottspeig
I am being asked to upload individual CAD files for each individual layout. The command I'm surrently using is "export layout to model", as I have no concern with the scaling aspect of it, but I have over 150 layouts in one file, and so this is a tedious task. I was wondering if there's a way to batch command this process like publish. Running AutoCAD LT 2023
pendean
Community Legend
Community Legend
@scottspeig wrote:
...Running AutoCAD LT 2023
Nothing in the software will do that, sorry. LT2023 is also limited on automation.
paullimapa
If you upgrade or install the trial version of 2024LT then you can automate this task using lisp
Paul Li
IT Specialist
@The Office
Crystal_Duck
Hi. There is no button for that task. You can try some lips on youtube channel
paullimapa
OP:
"Running AutoCAD LT 2023"
So no lisp for 2023.
Paul Li
IT Specialist
@The Office
scottspeig
I'm reviewing this topic for my office, as we have multiple designers that use AutoCAD differently (one set uses just model space putting borders & dimensions there, others use layout tabs etc).
Does full AutoCAD (not LT) export multiple layouts complete with hatching and wipeouts? This would allow each designer to create the drawing as they want, with the final product becoming individual files that can be updated individually.
pendean
Community Legend
Community Legend
So not ability to train or enforce standards, huh? That's the actual solution as you know of course.
Full AutoCAD and this free add-on will do it, you are welcome to try it in LT2024-5-6-7 and see if it works or not
https://marketplace.autodesk.com/apps/068ee7bc-7f50-432b-896f-f6bb37870526
HTH
