I'm trying to export DWG file from Chief to AutoCad LT but all I get is a blank file and this messege:
Non Autodesk DWG. This DWG file was saved by a software application that was not developed or licensed by Autodesk. Autodesk cannot guarantee the application compatibility or integrity of this file.
Appricite your help!
Carmit
@Anonymous,
john.vellek has edited your subject line for clarity:
Solved by john.vellek. Go to Solution.
HI carmitoron1,
Here is a link I found on the conversion process out of Chief Architect. Please let me know which format you select in your conversion and if your process is different than that described.
Please feel free to attach your converted file so I can see if the import is possible on my desktop.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
Thanks John for the quick replay.
I choose 2013/2014/2015 format (I have AutoCad LT 2015).
I'd tried to do it but it dosen't work.
Here's my DWG file. Hopefully you'll be able to understand that better 🙂
Hi carmitoron1,
I did receive a warning message about setting some Region properties but I went ahead and opened the file, zoomed extents and there it was. I did a purge and audit as well. I have attached the file for your information.
I have a DWG that was from Chief Architect from a client's architect and my architect uses AutoCad LT 2018. My architect said when she loads the DWG she can't use the line weights and other items. Could you work that same magic you did for the other person?
