Export Custom Settings for another user
martin_stevens2
Observer Observer
martin_stevens2
Observer
Observer
I would like to export 'my' custom settings for other users in my organisation. If I export my settings, and then import them for another user, the elements stored in my 'username' locations, are hard-coded to 'my' username, not .....\'CurrentUsername'\temp, for example. if there any way to amend these to be 'CurrentUser' and this work without manual intervention for others?
h_s_walker
What settings are you exporting?
If it's a tool palette you can edit the xtp file as it is a simple text file and you can do a simple search and replace in them
Howard Walker
Left Handed and Proud
martin_stevens2
Observer
Observer
Basically, all the settings that are collected into the Zip file by the Export / Import 'App' installed with AutoCAD .... some are linked to Local App Data / User specific locations, that get bound into an Export hard coded to the user that is exporting them
h_s_walker
The hardcoded settings you will not be able to sort easily, but any which are in a text file you can edit, just do a search and replace
Howard Walker
martin_stevens2
Observer
Observer
OK, thanks, seems a bit limited when sharing standard work etc. do you happen to know the code to replace the named user with the generic 'CurrentUser'  ?
h_s_walker
Unless it's in the text file, sorry no.
Howard Walker
