Error when duplicating in CAD 2027 it works fine in CAD 2022.
inphotodongtam4CUCW
Message 1 of 9
inphotodongtam4CUCW
Community Visitor
Community Visitor
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
@inphotodongtam4CUCW  Your screenshots are not from AutoCAD/LT2027. Is that your printer driver? Which one? Which brand? Which version? Did you try just printing to PDF to see if you can replicate the issue?
DO you have the 2027.1 update installed yet? it is required. Your LT's ABOUT command will confirm.
What exactly, in detail, is the challenge so everyone here can recreate inside AutoCAD without using 3rd party drivers and settings.
Message 3 of 9
BhaskarMurari
@inphotodongtam4CUCW The both screenshots correspond to the print drivers. Its difficult to check this. If possible share the drawings with exact issue screenshot.
Message 4 of 9
obulesub
Hi @inphotodongtam4CUCW ,
Thanks for reporting the issue. It looks like the community needs a few more details before they can determine the cause. If you're still experiencing the problem, please provide the additional information requested and any updated screenshots or examples that help illustrate the behavior.
Thanks!
Obulesu | Community Manager
Message 5 of 9
manieshkumar.suresh
Hi @inphotodongtam4CUCW,
Just give a try in AutoCAD, enter SYSPLOTCFG on the command line and set the value to 1.
Maniesh Kumar Suresh
Escalation Lead
If this information was helpful, please use the Accept as Solution function — it helps other users.
Message 6 of 9
inphotodongtam4CUCW
Community Visitor
Community Visitor
SYSPLOTCFG: 1 It's causing errors right away; using Ctrl+P messes up the print alignment
Message 7 of 9
paullimapa
Please show up by doing screenshots of each step you take before you get to your two OP screenshots.
For Example:
Step 1:
Ctrl+P screenshot looks like =
Step 2:
Paul Li
IT Specialist
@The Office
Message 8 of 9
inphotodongtam4CUCW
Community Visitor
Community Visitor
Here are the details regarding the printing error in AutoCAD LT 2027.
I have tested versions ranging from 2022 to 2027; only AutoCAD LT 2022
is free of this issue. In the other versions, the print output is
misaligned—specifically, there is a consistent offset (regardless of
how many copies I generate, the misalignment remains the same).
Message 9 of 9
pendean
Community Legend
Community Legend
@inphotodongtam4CUCW wrote:
...I have tested versions ranging from 2022 to 2027; only AutoCAD LT 2022
is free of this issue...
In that case, you'll need to open a support ticket through your accounts page and in the interim find a workaround since it is unlikely to get fixed anytime soon sadly.
