AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
ERROR - Unhandled Access Violation Reading 0x0010 Exception at 50f839a6h
4 REPLIES 4
4647 Views, 4 Replies
my autocad lt 2018 keeps freezing and then shows an error message. not sure why please help i have attached a picture of the message that pops up
@Anonymous,
john.vellek has edited your subject line for clarity:ERROR MESSAGE
4 REPLIES 4
john.vellek
Hi @Anonymous,
I suspect that this error reflects some corruption in your Windows 10 or .Net Framework.  Here is an article that list some steps to remedy this issue.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
TobiasPio
in reply to: john.vellek
Link in solution is broken. Please renew.
michele.mk
in reply to: TobiasPio
Hello @TobiasPio,
thank you for reporting the broken link. It might be that this article has been replaced or changed the place. I will investigate internally.
In the meantime you can try the following to solve the issue:
Error: Unhandled access violation reading 0x000 exception
Error: "FATAL ERROR: Unhandled Access Violation Reading 0xfffffffff Exception at d2fea7c0h" in AutoC...
I hope this helps.
Best regards,
Michèle.
Ihr fandet einen Beitrag hilfreich? Dann vergebt dafür Likes!
Eure Anfrage wurde erfolgreich gelöst? Dann einfach auf den 'Als Lösung akzeptieren'-Button klicken!
Michèle Matzeck-Kunstman
Technology Administrators
