Good morning,
the normal way I copy, move, delete, trim object was normally just dragging a box around what I wanted to move click the move, copy trim button and then moving etc the object in question.
I now have to select what I want to use or type the command in, select a box around what I want to move for example press enter and then move although this does not seem like a big issue it is slowing me down. as im use to the first part of this question and I don't know how or why this has changed for how I move or copy or trim etc anything and its kind of annoying any help or advice would be greatly appreciated.#
plus now I can not even move veiwports or enter into a text box by just double clickingor by just dragging round and moving instead of the cross hairs a little box comes up
Thanks.
Danny Unwin.
Solved by h_s_walker. Go to Solution.
At the command line type PICKFIRST. Change the variable to 1
Howard Walker
