Dynamic blocks automatically exploding
aaditya.desai
aaditya.desai
Hi all,
I am facing an issue while working with the dynamic blocks from a pre-made template. While working with it, a particular block explodes after some time. For example, when I use any block and do the work with it like copy-paste it, after some time when I save the file it shows exploded.
Also, I made a copy of the original template to check if I put any command by mistake to cause this error but it is not there.
I do not understand how it happens. Waiting for some resolution on this.
pendean
Community Legend
Community Legend
DWG file with the auto-exploding dynamic block in it would be way better to share around here than a pretty picture: explain how we get there.
NOTE: if you cannot replicate it on demand all the time then no one else can either; in which case its just a random hiccup or a missed action, nothing more. That happens to all of us.
aaditya.desai
Hi @pendean,
Thank you for the response. I cannot share the template here because it is confidential but I understand your response on this issue. There may be some bug happening.
steven-g
Very doubtfull that it would be a bug. If you cannot share the template could you just place a copy of one of the types of blocks into an empty new drawing and post just the block. A copy of one of the broken blocks as well might show us something.
