I am struggling with drawing units. I need to change the units from milimeters to inches. It works all fine with using -DWGUNITS except arrays. All the arrays of blocks are scaled actually two times so the objects appear smaller. The blocks have are defined wtih mm units. Single blocks (not in array) are scaled correctly. If I set the block unit to unitless it scales correctly but that doesn't sound as a good solution to me. Could anybody help, please?
OK I tried a test, indeed odd behaviour, not what I would expect from running the -dwgunits command, it would be worthwhile posting this in the product feedback pages and see if you get a response from there, but yes, for now, the way around this is to make the block unitless (at least prior to running -dwgunits).
check the settings of the block whether its set to scale uniformly or not and it's units and whether it's annotative. HTH
You may have your issue there in front of you. If your block is in mm and you stated you want in inches. Scale the block with the scale factor going from mm to inches or redraw the block in inches. The actual drawing is it in mm or inches? Lots to check and make sure they match.
The issue is that I work in mm. But if I want to send the drawing to colleagues in U.S. I use change the units by -DWGUNITS. The test file is made in mm just to test the units conversion. Try to apply -DWGUNITS and will see what happens.
You need to figure out your conversion factor and scale your drawing accordingly. If I had a drawing in inches and I need it to be in feet, I would scale the drawing by 12 and reset the units.
eeeeeeh. I know math. But there is a tool how to change the units in more sophisticated way. Additionally, when U.S. people try to use scale factor to scale from inches to milimeters they always fail as they always round the scale factor (1/25.4)...
