Drawing specific regen crash is spreading.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We have an odd problem occurring, and it is now occurring on multiple machines and growing to multiple files.
Starting sometime last year, we begun having an issue on one DWG file only, where the file would hang/crash when switching back to model space from a particular layout. The file was accessed with multiple machines with various graphics cards, all running AutocadLT2015, and all with the same result. You could use the file with no issue, but when you worked on (in this case the foundation plan) you had to remember to switch to a different layout first before switching to model space. Switching directly from the (foundation plan) would hang/crash CAD at regen.
That particular file has been recovered, audited, copied to a fresh template, etc... all with no effect. We have had no choice but to simply "quarantine" the file and make certain not to go back to it to copy any details/etc. Which worked for a while, but not we have the issue popping up again on another job.
Same scenario. On one DWG only, and when accessing one particular layout (in this case the wall section sheet) cad will hang/crash. This leads me to believe the issues is entity based not setting based but I cant figure out what could possible be causing it. Thoughts?
