Most read-only variables are set or controlled by certain commands and
settings: some are not. A quick browse through HELP and TIME command, could
not see anything that would specifically reset TDINDWG, although I did not
try to see if creating a WBLOCK from the drawing resets it on not.
If you create TEMPLATE files in AutoCAD then a new drawing from it, is
TDINDWG reset in the new drawing file (not the way you describe in your
post, but actually using the Template option in SAVEAS to create)?
Dean Saadallah
www.pendean.com
"bdsellers" wrote in message
news:f0c4b34.-1@WebX.maYIadrTaRb...
> When I copy a drawing as the basis for a new drawing, the properties of
the old drawing, particularly "TDINDWG", remain. Is there any way to reset
read-only drawing properties?
