Drawing Properties are not working on AutoCAD LT
syanchuck
Message 1 of 22
syanchuck
Trying to change value on the "Drawing Properties, but it won't work. Could you please help me?
Accepted solutions (3)
Replies (21)
Message 2 of 22
pendean
Community Legend
Community Legend
What doesn't work exactly? Explain, elaborate, what did you use and what was the result.
What OS are you using? MacOS does not have "drawing properties" for example. If that is what you are using you are also in the wrong forum.
TIA
Message 3 of 22
syanchuck
Here is the template drawing. I want to create to my client the similar one.
But that template I've created by the Standard AutoCAD.
If I add a page, I am going to:
Drawing Utility--->Drawing Property--->Custom:
Drawing PropertiesDrawing Properties
Here I can add the total sheets number, so I don't need to go to every single sheet for the changing total number.
That function doesn't work now.
My question:
Is it because LT doesn't have this function or because I didn't something wrong?
I don't have Standard AutoCAD, do not have an option to check if it works on the Standard AutoCAD.
Thanks in advance!
Message 4 of 22
syanchuck
Sorry, didn't mentioned, working on Windows 10
Message 5 of 22
pendean
Community Legend
Community Legend
You did not quite explain, what is stopping you from doing that in LT?
Are you perhaps asking about extracting that data perhaps?
I can add any entry I want there in AutoCADLT here, no issues:
Message 6 of 22
steven-g
Your drawing layouts use a block that presumably needs to show this sheet number. Unfortunately, that block isn't set up to show that dwgprops information, you would need to add a field either directly to your block or within an attribute, your title block now just contains a plain text item?
Message 7 of 22
syanchuck
If I change Total sheet here:
then doing "regen". After that Total Sheet supposed to be changed here:
However it won't work.
Message 8 of 22
pendean
Community Legend
Community Legend
Is that a field in your titleblock? It does not appear to be, looks like someone exploded it.
What is it referencing/where is it getting info from if it is a field?
Message 9 of 22
steven-g
There is no link the 4 in your title is just plain text in an attribute, maybe at some point you had a field in there but looks like maybe someone edited the block because it isn't in the block definition either.
Message 10 of 22
syanchuck
Oh, how comes...
Thank you both, Steven and Pendean!
Could you please remind me, how to create the reference now?
Thanks!
Message 12 of 22
steven-g
Open the block in block editor. Double click on the attribute and then where the "4" is delete the 4 and then right-click and choose 'field', from the list on the left hand side go all the way to the bottom to find the dwgprop total-sht. Now save the block and in your drawing run attsync and select the title block to update the information, (possibly you might need to reinsert the title block). Then when you make the change in your dwgprops you will need to do a regen.
Message 13 of 22
syanchuck
Hi Steven,
Thank you for your solution.
I found "Field":
But on the Block Editor I don't have "4", only the attribute:
And if I delete that attribute, not clear where I DoubleClick.
Thanks in advance for clarifying.
Message 14 of 22
steven-g
No don't delete the attribute, double-click on the attribute and delete just the number 4 that is in the attribute default, then right-click in that default box and select insert field, it is here that you place the field value you have found.
Message 15 of 22
syanchuck
It works on the attribute but it does not work inside of Block editor. It let to insert the field, but finally it is not catching up.
I will accept your solution on the end of the day, but I wanted to find out why it doesn't work inside Block Editor.
Message 16 of 22
steven-g
Works just fine here. Did you save the changes to the block and did you run the attsync command after making the changes, once you have done that then you should see a slight greyish background color around the number (this indicates that the text is now a field). When you make changes to the dwgprops you will need to run the 'regen' command in order for the fields to update in the title block. See the attached.
Message 17 of 22
syanchuck
I to do the same with "REVISION", it works from outside of BLOCK EDITOR, but from inside it doesn't. Will try to check it Monday. I can't do it from home.
Thank you anyways, since I can use it.
Will let you know Monday.
Message 18 of 22
syanchuck
Once again, I am trying to understand why it doesn't work inside of Block Editor.
Went there again, inserted "Field" and then, I got that:
And then I simply pushing "Enter". After that I am saving the Block Changes (by the way, Block Test is not working). So, I am testing my changes outside of the block editor, but the "Field" is still not inserted.
Trying to understand what's the issue...
Is that reason why
Message 19 of 22
steven-g
Have you run the 'attsync' command, any existing blocks don't automatically update you have to run attsync and select one of the existing blocks, this causes the block to recognise that you have changed an attribute setting in the block editor. Plus after you make changes to the dwgprops you need to run regen.
Message 20 of 22
syanchuck
Yes, I did. That is useful command for updating all other attributes, however the "Field" function still doesn't work inside Block Editor.  That is not very important, I fixed everting from outside of Block Editor.
Still need to figure out how to where to find Sheet number:
I wanted to insert "sheet layout name" as a sheet number, but I don't know what Prop to select.
Will be very appreciated you for your help!
