AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Can't use feet anymore only inches lenght works
3 REPLIES 3
796 Views, 3 Replies
For some reasons (and it's very possible that i've touch someting that i should'nt) i can't use feet (') distance for move, line, rectangle tools. I can only enetr the inches dimensions. My units are in Architectural. I put the symbol (') after my lenght. And it doesn't work, Please help me!
Exemple of command that i try to do: DP-Clic on the line that i want to move-Entrer 3' - The command line tell me that the point incorrect.
It doesn't happen with all of my Autocad documents. And it switched while i'm using it.
I noticed that after the Ortho label on the screen, the number is in decimal for the documents that i have problem with, and is in fraction when the document is ok. How can I change this set up?
Thank you!
Labels (1)
3 REPLIES 3
pendean
Show us, post your actual DWG file, because what you write and what you show do not jive at all.
in reply to: pendean
Thank you for the answer. But only with the picture can you help me finding why they are different?
Found it. My units were on decimals.
Technology Administrators
