drawing in 2D
drawing in 2D
drawing in 2D
   I may not be able to explain this correctly but let me try. I have been using autocad LT for many years. With the new 2017 version, I notice the UCS iso drawing. Anyway, some how I got into drawing on this plane. I only want to draw in the 2D or x,y coordinates. I have tried many different things.
turned off the UCS icon
tried to flatten the drawing
tried to change all properties to elevation 0.
it still kicks me back to drawing on the x,y,z axis. I hope this is as clear as mud. Can anyone help me to only draw flat?
Thanks, Trena
pendean
Community Legend
Community Legend
There is always a Z-element in AutoCAD/LT. Always.
Are your objects actually in a Z>0 setting? Or are you just staring at a flat plan in iso view?
If the latter, UCS command set to WORLD and PLAN command set to WORLD is the best way to get back to flat 2D-land view in the model.
sthompson1021
If I'm understanding your mud correctly, type the command ISODRAFT and select the orthographic option.
Emmsleys
Following up on your thread, did any of the post's help? Post back with any additional updates if you continue to have an issue.
Thanks.
Sarah Emmsley
Technical Support Specialist
