Double lines
Double lines
Message 1 of 9
Double lines
Just downloaded the trail version of LT 2021.
Just having a play before I use in anger 😎
Trying to draw double lines. Help suggests I should be able to but can't find it anywhere.
Replies (8)
Message 2 of 9
Use the command "Mline"
Message 3 of 9
or "dline" at the command and specify width? (found this by searching this forum....doh)
Message 4 of 9
cadffm
Use command: DLINE
to create two (separate) parallel Lines
Or create one Line (often better:  one Polyline) and use command: OFFSET to create the parallel seceond one.
MLINE is very special, i prefer to not use mlines for beginners (mline beginners)
For all Commands: Read the help [F1]
(Quicktip: Start the command and press [F1])
Sebastian
Message 5 of 9
steven-g
There is no mline command in LT, try dline
Message 6 of 9
yes dline seems to work great thanks everyone.
How do I add a dline command to a toolbar?
Message 7 of 9
pendean
Community Legend
Community Legend
Toolbar (old school)? OR Ribbon? If you don't know, I suggest you just add it to the QAT https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Au...
HELP is a good place to look into how to add commands to the user interface https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Au...
Message 8 of 9
Old School 😂 That's me to a tee. Trying to use this after a 15 year break from LT 🙄
Your right whats easier than typing dline but I'd like to add it to a toolbar too 😋
Cheers everyone. Impressed by the help. Much appreciated!
Message 9 of 9
pendean
Community Legend
Community Legend
I abbreviated DLINE to D in the PGP file, another option to consider https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Au...
