When I use the distance tool to measure, the measurement info appears on the screen but fades away too quickly. Is there a way of keeping the distance results info longer on the screen?
Solved by Emmsleys. Go to Solution.
Solved by steven-g. Go to Solution.
Using the command history window (F2) is a good idea. Try applying that to your workflow and post back if you have any other questions.
