Display plot style in paperspace
Message 1 of 10
Recent upgrade from 2007 to 2016. Where in 2007 i would click apply to layout and the paperspace would be as per the print, ie not colours but black lines.
Currently any existing drawing i have opened shows the line style as the colours like model space. I know i can go to the layout tab, right click and navigate to tick the box to show display plot styles. This is fine but i was looking for an automatic approach like i had before on 2007 where i would just 'apply to layout'.
Thanks for any advice.
Replies (9)
Message 2 of 10
rkmcswain
"Apply to Layout" simply saves the settings in the PLOT dialog to the layout.
You still need to check on Display Plot Styles in the page setup.
You can turn this on in your template(s) and it will be On in layouts in drawings that are started from these template(s).
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 10
Emmsleys
Hello @Anonymous
Try the suggested options in Assign plot style table's in model or layout tab let me know if this is what you were looking for.
Sarah Emmsley
Technical Support Specialist
Message 4 of 10
rkmcswain
The OP is wanting to apply the plot style to the layout - not change plot styles, which is what that article covers.
Message 5 of 10
Emmsleys
Thanks @rkmcswain for clearing that up.
Did that help your issue @Anonymous ?
Sarah Emmsley
Message 6 of 10
Emmsleys
To revist this thread,
I believe this was the article that was inteded to be added after R.K made the correction.
Apply plot style to the layout.
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
Message 7 of 10
boicottms
hello,
I would like to find the commands to avoid going trough all those clicks.
Message 8 of 10
Yes too many clicks especially for large projects with so many sheets.  Is there a command or way to apply through a template?
Message 9 of 10
pendean
Community Legend
Community Legend
If you are using the LT version of AutoCAD (where you are posting) your discounted software price limits your ability to anything custom.
If you are running full AutoCAD then start your own topic detailing exactly what you need here and see what other users can offer https://forums.autodesk.com/t5/autocad-forum/bd-p/706
Message 10 of 10
I didn't realize this was LT.  We run the full licence.  I'll try in another forum.
