& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
I typically don't work from civil plans but in this case, I need to spot out equipment and bldg to bldg infrastructure but with is being a plan provided by the civil contractor its automatically adjusting everything to the direction of the true north orientation of the plan. I tried some of the UCS options but I guess I am not understanding what I need to change. I was advised that in Autocad 2019 there was simply an option to zero out the UCS the remove the coordinates adjustment but that doesn't seem to be the case in LT. So basically I just want everything to stop tilting to match the tilt of the true north arrow on the sheet. Its doing this for any block I insert of something as simple as drawing a rectangle. Thank you for any suggestions.
I tried using the world command, and its certainly possible I did it incorrectly, but all it did was change the North arrow and the x/y axis to physically pointing straight up visually on screen and tilted entire plan to the original angle of the north arrow. Let me ask it another way in case I said it wrong. I want the siteplan to stay as it sits on screen horizontally left to right and remove any fixed orientation that effect anything new that I add.
Let me also clarify that my experience is minimal as I am generally only adding spots, dots and lines to another persons drawing so bare with me if I am not explaining my issue the right way.
If WORLDUCS returns 0, then type in UCS, and press <enter>, then type in "W" and press enter. Next, type in PLAN and press <enter> twice. Confirm that WORLDUCS = 1 now.
It reported WORLDUCS=1 (read only).
I went ahead and proceeded with steps you provided so I would have a better understanding of the effects and it adjusted the on plan North Arrow to pointing straight up instead of tilted and the plan with it. After I did those steps worlducs is still 1 but I just selected the entire plan and rotated to a horizontal view and was able to place a block without it automatically applying an angle of tilt to it. I think that's a "close enough" fix for now but I sounds like I need to learn this subject better matter to better handle it in the future. It sounds like there may have been a problem with the originally drawing based on how you described WCS because it was set to 1 but North was not up it was about at about 30 degrees right of on screen up.
Thank you for the help
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD LT forum.
It looks like @rkmcswain helped out with a workable solution, but I wanted to follow up and offer this link to the Autodesk Knowledge Network article on the UCS. It's a good starting point for basic info on this system, and the Related Concepts links at the bottom will allow for a deeper dive into specific subjects.
About the User Coordinate System
If any post in this thread answers your question or solves your issue, please click Accept as Solution so others in the community can find it easily.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
