dimentions copy from other shape
I have a question about copying dimensions of an rectangle.
Lets say i have an rectangle with the dimensions of 100 x 100 mm.
When I want to use this dimensions with a -2 mm on the left startingpoint and a +2 mm (typing in the commandbar) at the right endpoint, I used to have an rectangle with the dimensions of 104 x 100mm.
But since the update to 2021 LT he only uses the height of the object, so when I enter the last (+2mm) measurement  this results in an rectangle of 2 x 100 mm.
Is there a setting to activate the former settings?
pendean
Community Legend
Community Legend
Forgive me, but I am not familiar with what you are trying to do (in the old version or new): are you just having a problem stretching your rectangle object with grip editing? If yes, what is your DYNMODE set to?
or do you need to turn off your running osnaps first?
steven-g
If you are not placing your dimensions to your actual rectangle they cannot be associated with the geometry and will not adjust with it
