Dimensions rounding when changing font color
jacobNFVKG
jacobNFVKG
Community Visitor
Community Visitor
Hi all,
Been having an issue where I create a part using SolidWorks, then make a drawing of that part also in SolidWorks. From here, I save this drawing as a .dxf file. All dimensions are transferred correctly, however, when I try to change the font color all the dimensions round to the nearest 1/8" as seen in the video attached. Any help to stop this from happening would be greatly appreciated, thank you!
(view in My Videos)
pendean
Community Legend
Community Legend
@jacobNFVKG Looks like your dimension overrides are being removed or your dimstyle is getting updated to match the predefined DIMSTYLE settings in that DWG file.
Can you share your actual DWG file with that content in it here?
paullimapa
goto that dimension style using DDIM or DIMSTYLE command select that style choose Modify and match following settings
Paul Li
IT Specialist
@The Office
