AutoCAD LT Forum
Dimension Text on Dimension Line Issue
8 REPLIES 8
Message 1 of 9
3648 Views, 8 Replies
Hello Helpful People,
I am drafting on Autocad 2017LT and I keep encountering  the same issue when I alter the location of a dimension by moving the dimension text via insertion point. The point that is causing the issue is the one with the cloud drawn around it, dimension 1 in the attached image. The error occurs with dimensions that have text overrides. The text override that I am using is <>\X . Dimension 2 in the attached image is an example of a dimension with text override that is functioning properly. Dimension 3 in the attached image is an example of a dimension with text override that is not functioning properly, and had its text moved by the insertion point. This issue only occurs in dimensions with text overrides, as shown in dimension 4 in the attached image. The only preventative measure I have found is to not move the dimensions text after I put in the override. This typically occurs accidentally when I am stretching near by lines and I do not notice that i selected the text in the dimension, but this is also an issue when I am trying to make the dimension have a leader. A solution I have found is to add a line space in the dimension text override, which makes the override <>\X\P , but this also produces issues. When adding a line space to the text on the bottom, it causes the text to be too far below the dimension, which can be confusing when there are numerous dimensions in close proximity. See dimension 5 in the attached image to see the difference between a dimension with override that has not been moved (red dimension) on top of a dimension that has the line space (yellow Dimension).
Does anyone have any other solutions to this problem asides from deleting the dimension and starting over?
8 REPLIES 8
Message 2 of 9
h_s_walker
Instead of using the \X override, have you tried editing the dimension itself. Dimension text is MTEXT and you can edit it just like normal mtext
Howard Walker
Left Handed and Proud
Message 3 of 9
steven-g
Instead of using "<>\XDLO" in the text overide, use "<>\pxsm1.25;\XDLO" you will have to adjust the number 1.25 to suit your needs but that tells Autocad what line spacing you want (I use metric but I believe the number is a percentage of the standard text spacing).
Message 4 of 9
Emmsleys
Circling back to your thread, did any of the posts in the thread help with you issue?
Post back with any new updates. I'd be happy to try and help.  Thanks.
Sarah Emmsley
Technical Support Specialist
Message 5 of 9
in reply to: h_s_walker
Hello Hwalker,
I tried editing the dimension as a MTEXT item, but it also produces the larger gap between the dimension line and the text below the dimension.
Thank you for your suggestion.
Message 6 of 9
in reply to: steven-g
Hello steven-g,
Your suggestion fixes the issue of the text being on the line, and it maintains the location of the text even when moved.
Message 7 of 9
Raisaac123
Very interesting answer. I just couldn't make it work
When I type your line the dimensions just shows me what I typed, not the effect of it.
If you could please try to explain these options again.
PS. I use  <>/XSETBACK  for example when I want two lines, the actual dimension on top and the word SETBACK at the bottom, the /X disappears and I am left out word only. only problem is that when I move the text to another location within the dimension line, the dimension line dissapears and I want to keep it with the dimension above and text below just as it when the text is homed
Message 8 of 9
Raisaac123
Joel, I couldn't make this work, could you please explain what you typed after ?
EX:  <>/XSETBACK  for dimension above and word SETBACK at the bottom. When I move the text, the dimension line disappears in the section. I think the 1.25 is to give it more space but the prefix just didn't work for me.
Message 9 of 9
pendean
in reply to: Raisaac123
fdml >>>...the /X disappears...<<<
It is supposed to, that's by design.
>>>... move the text to another location within the dimension line, the dimension line dissapears...<<<
That's most likely a missed DIMSTYLE setting. Show us your work, post your actual DWG file if you can. and let everyone know your exact LT versions.
TIA
Technology Administrators
