Dimension style
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using AutoCAD from last 4 years. Today, while working with dimstyle, I have got a problem in placing tolerances. In single dimstyle, I was able to put one type of tolerances (upper limit and lower limit). For example, 12 +0.1/-0.2.
But, applying dimension to othger dimension such as 30 same dimension (+0.1/-0.2) was displayed with dimension value.
I want a system that will automatically modify the tolerance value. For example, I have a chart which includes tolerance ranges, see below
VALUE Tolerance
0-10 0.1
11-20 0.2
21-30 0.3
It would be better if I can specify a parameter/variable in AutoCAD which will automatically change the tolerance value. For example, for 10mm tolerance, will be 0.1, and for 20, tolerance will be 0.2
