Dimension style changed (ghost in the machine) and now cannot be modified back to original
mbetGEGZX
mbetGEGZX
Was working on drawing and noticed the dimension style changed from having tick marks to some kind of target. Am unable to revert back to the original.
cadffm
I would say: Nothing changed, except you *current* dimstyle setting.
Why my guessing: You used dimstyle ADF  and ADF Fraction
and only one dimension uses dimstyle Standard (what is current now)
If this is your issue, set ADF or ADF Fraction as current.
(you are the only one who knows which one you want to use)
Command: DIMSTYLE
or
Command: -DIMSTYLE restore ADF or ADF Fraction
Sebastian
cadffm
or do you speak about ADF and ADF Fraction ?
then
Command: DIMSTYLE
Edit ADF or ADF Fraction
Tab Lines, remove the supress dimline options
and on the second tab for symbols and arrows, change the arrow size
and all other settings you have to "restore"
Sebastian
cadffm
Hint: Would be easy to recreate or swap to, if you have another DWG with the dimstyles
which have the settings you want. Is there not an old version of this DWG, or another one with this style(s)?
Sebastian
pendean
Community Legend
Community Legend
Greetings @mbetGEGZX
You have three dimension styles defined in your DWG file, and the bottom one is set to be the current. Question is back to you, which one are you supposed to be using? We can't answer that for you, but you yourself can change the default anytime using DIMSTYLE command
mbetGEGZX
Standard is what it was set at. Trying to clear out the remaining dim styles
