BFIND LISP not working. ** Error: Automation Error. Description was not provided. **
mcrossley8MJ5B
Message 1 of 9
mcrossley8MJ5B
Recently I have updated to CAD2024 and been making use of LISPs, however, one of the most useful LISps I used at my last company (which was on full CAD, not LT) was BFIND by Lee Mac, this doesn't work at all for me now though and I get an error "** Error: Automation Error. Description was not provided. **"
Has anyone come across this error before? I am unsure how these work but could it be because I am using LT?
Replies (8)
Message 2 of 9
cadffm
>>"Recently I have updated to CAD2024"
Ther is no Autodesk program "cad2024", you mean LT2024 or AutoCAD LT 2024" ? okay
>>", this doesn't work at all for me now though and I get an error "** Error: Automation Error. Description was not provided. **"
>>"Has anyone come across this error before?"
Everyone who tries the same.
>>"I am unsure how these work but could it be because I am using LT?"
Yes it is.
Lisp is new in LT and it doesn't provide 100% of all Lispfunctions, just 99.9% of them.
Because of this, nobody coded an "LT-Version" and if one or more of
the 0.1% functions are in use, it won't work in LT.
For you:
If you have a readable source lsp file (as you have in case of bfind),
check the code of vlax-create-object or vlax-get-create-object,
these both are the most used functions of the 0.1% not supported functions in LT
For Users with programming skills:
To use Bfind in LT, you have to edit/replace the popup function - what is simple,
and the part to store the settings&value globally *REX*,
because you need to get rid of the vlax-create-object - what needs more time, or you get
a ready programmed sub function for this task.
Sebastian
Message 3 of 9
pendean
Community Legend
Community Legend
LT remains handicapped, LISP in LT2024 is limited and not full-on free-for-all
If you need for every LISP out there in the universe to work, you need to subscribe to a CAD package other than AutoCADLT.
Message 4 of 9
mcrossley8MJ5B
Ah, then it is LT that is  the problem. Thanks for clearing this up.
It is a shame but not too much of a big deal at my current company. Thanks for the reply.
Message 5 of 9
mcrossley8MJ5B
Thanks for the reply, unfortunately I have no coding skill so will have to do without, or maybe try a plugin.
Thank you for the information though.
Message 6 of 9
lschuhWQKEV
Observer
Observer
Hi. I am having the same problem as OP. I found "vlax-get-create-object" but I'm not sure what to replace it with. I am not a (very good) programmer and this is my first introduction to LISP. I am also very new to Autocad.
Message 7 of 9
pendean
Community Legend
Community Legend
@lschuhWQKEV LT2024 cannot run that code, Autodesk decided that limitation. Sorry. You'll need to find a different LISP that has similar abilities, if it could be replaced easily someone would have tackled it by now.
Message 8 of 9
lschuhWQKEV
Observer
Observer
Okay, thank you. I figured it wouldn't hurt to ask.
Message 9 of 9
cadffm
>>" this is my first introduction to LISP"
Your welcome, but this not the perfect task to start with 😄
The easy part, the popup, how to change:
but the bigger part is to replace the RegExp/RegularExpression part.
You need a similar function, without using vlax-create-object "VBScript.RegExp".
Still trying to edit the lisp on your own?
Search for "search and replace" userdefined lisp functions (without VBscript).
EDIT: GetInterfaceObject is also used and not supported in LT !
As I said, it is not the perfect task to start with.
Search for another tool which works in LT.
Sebastian
